D14 and 3 bottom value
wi1475 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi1475 Quote  Post ReplyReply Direct Link To This Post Topic: D14 and 3 bottom value
    Posted: 13 Mar 2015 at 11:58am
I have an option to purchase a 1959 D14 with a front loader and rear scraper as well as a AC 3 bottom plow.  Tractor is functional but has been outside for about 20 yrs and looks rough.  Same for the plow.  I am wondering what a fair offer would be in your opinion?  The seller is sort of a friend who is selling due to health reasons and will consider offers and I want something fair to both of us. Thoughts? He is also selling an old Krause 4 row disk but as this is a AC forum I will try to ask about that elsewhere unless someone has recently purchased one or has an idea on that.
B26240 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 3:56pm
How does it run? Have you driven it? Three big factors that can affect the value are does the transmission jump out of gear (usually 2nd or 3rd) What are the rear rims like? As it has a loader on it it is real likely they are filled with fluid, look at area around valve stems. What shape are the tires in? New rubber is expensive. If you give us more info someone may throw out a figure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi1475 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 4:02pm
It runs and does not jump out of gear in 2nd or 3rd as many are known to do.  It runs fine, starts a little hard and battery does not recharge well. Rubber is not new, front tires are quite old but I do not see many cracks and all 4 hold air.  Rears are not worn or cracked but definitely not new either.  I do not believe the rims have fluid in them, rims are not very bad shape, minimal rust. Loader frame as 1 weld but looks straight and well done.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 4:02pm
Power Steering is a big plus
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi1475 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 4:11pm
Power steering works and it had a new clutch installed about 5 or 6 yrs ago.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 4:13pm
Somewhere between 1500 to 3000 without seeing it . Check clutch pedal 'diamonds'. If well worn, she's seen a lot of loader use. Also check from rims as heavy weight/use will fracture them at the 'bolt circle' due to stress. Not charging could be  in need of a genny rebuild though I'd just put a CS-130 in it.
I'm kinda partial to the D-14, probably offer $2000, be happy to deal at $2500 IF it has power steering ! Without it, using the loader WILL develop your arm muscles !!!
Also , check the brakes !! When the diff axle seals leak, there goes your brake shoes. Yeah I've got 3 D-14 and one brake out of 6.... 'it's on the todo list'.......
Jay
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 9:26pm
If it looks rough (banged up/missing sheet metal), no more than 1500 for everything.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 9:58pm
    Pictures would really help here .Can you post any ? Would help a lot . You also mention a 3 bottom plow but do not offer a description . Is it field ready or scrap man special ?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2015 at 6:57pm
From what you say, my estimate would be $1500 to $2000.
Dandan111 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dandan111 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2015 at 9:40pm
If you have a use for that d14 it's worth whatever your willing to pay within reason. You can't buy a new tractor equal to that d14 to use without breaking the bank in my opinion. Depends on your location for price. You wouldn't buy that tractor around here for $1,500. I would venture to say $3,000 or more in my area. Look on tractorhouse.com
