185 suprise |
Post Reply ![]() |
Ben (MI) ![]() Orange Level ![]() ![]() Joined: 02 Jun 2010 Location: SW Lower MI Points: 768 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Mar 2015 at 7:45am |
I am finally doing some work on the 185 I got a year a ago and have used very little. I have the fuel tank at a radiator shop being cleaned and coated due to lots of crud inside. Here is my surprise from yesterday when checking the air filter. I think I will replace it! I like the AC logo on it.
Part time farming with a 1980 7060 and 1984 F3 hydro.
Gary(WI) ![]() Orange Level ![]() Joined: 27 Nov 2009 Location: WI Points: 1005 |
We found 1973 filters in a 1855 oliver once. It wasn't 1976 when we found them either. Gary
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5097 |
so if the tank was full of crud, I can only imagine what the pump and injectors are like!
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
That isn't uncommon. People didn't spend money on things years ago like we do now. You blow filters out put them back in.
IG |
BradRisen ![]() Orange Level ![]() Joined: 09 Feb 2012 Location: KY Points: 265 |
Or take a clean five gallon bucket ,warm water, and some detergent ,and gently hand wash the filter ,let dry naturally, no compressed air while wet, then re- install,almost as good as a new filter.
EricPA ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Watsontown,PA. Points: 2578 |
Been there, done that ! ![]() |
Life is tough,but it's tougher when you're stupid. - John Wayne
ryanschott ![]() Orange Level ![]() ![]() Joined: 10 Apr 2010 Location: michigan Points: 612 |
ill take a pic of mine my 185 has the original late 79 filter and its a 1980 model i have it cleaned spotless though. tractor has 2400 hrs i do believe
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8720 |
I'll replace an air filter vs replacing an engine any day of the week! Darrel
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
I send my filters out for cleaning, not that expensive and as long as you don't wait too long, they look good as new.
Allis Express participant |
Good stories. My practice is to clean air filters and only replace when light shines through less than I think it should.
In regards to the fuel tank, the pump and injectors have only a few hours on them. Hopefully the sediment bowl and filter kept them clean. Edited by Ben (MI) - 09 Mar 2015 at 6:23am |
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Had a D19 that the intake hose was removed from the carb when we bought it. Put it back on and the tractor would not run. Had to remove the air cleaner from the tractor and destroy the element to get it out of the housing, was packed full of dirt. I think I was the first person since west allis to have that element out.
Edited by Butch(OH) - 09 Mar 2015 at 8:44am |
Butch-I can imagine that good Ohio clay as dust packed in there like concrete!
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1784 |
It's remarkable what some of these tractors have went through and still operate.
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
I believe I saw at a farm show once a mechanism that hooks to the end of an air hose that has a small rotary thing one the end that you insert into the filter to clean it out. The rotary part spins really fast and shoots air out of the filter, removing a lot of the dust. |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Wink I am a Russian Bot |
Post Reply ![]() |
