Oil Leak
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Topic: Oil Leak
    Posted: 05 Mar 2015 at 4:32pm
Here's a photo of the oil leaks Don. The far left leak is from the hand clutch seal. The largest spot in the middle is the leak coming from between the clutch housing and the torque housing. It's not coming from any where near the belt pulley or anywhere inside the frame near the belt pulley. It's not wet anywhere above the very bottom of the case. The hydraulic fluid no longer reads on the dip stick. These puddles are 6 hours old. A drop of oil drips every 2 minuites. I can't wait till the reservoir is empty. The very front larger spot is gas dripping from carb and the many smaller spots are from engine because I have the pan off. Everything is 65 degree room temperature. The tractor hasn't been started for weeks. Note tennis ball for size reference.
I just need to know the proper procedure to getting to whatever is in there for a gasket or seal between the cases. Can I unbolt the frame from differential and spit it where the clutch housing meets the torque housing, or do I need to pull the engine and work my way back?
P.S. Hurry, dog wants her ball back.......
Edited by Les Royer - 05 Mar 2015 at 4:34pm
I still gots my A/C but it's clear out in the barn now.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 5:31pm
Looks like your job foreman is under there having a look too.......
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 5:50pm
I think the dog is having you on, he made all them spots, lol!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 6:14pm
I sent you a PM about your oil leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 6:19pm
FYI most old tractors mark their territory with oil spots, kind of like your dog will make his territory with well you know. lol
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 6:38pm
Cute dog is that a king Charles Spaniel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 6:47pm
Les,
 Looks a lot like under my WD. Don(MO) has helped me on several things. Your hooked up with a good AC man for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 8:36pm
Yeah, Cal. King Charles spaniel Bichon mix. 2 year old female
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 12:42am
awwww...Les...throw a little dirt over them leaks...that's seal em up! lol
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 7:21am
I use that "twice as good" oil dry from Sams club.
My trick is to always park in the exact same spot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 9:27am
If you'd put grating in that floor, you'd never see it.  OR, park in on sand.  Only shows a small dot.  LOL
I feel for you.  You're gonna half to dig into it if you want to fix it. Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 12:18pm
Don was kind enough to mentor me on this one. Gonna be giving him a call after the meet. Looking forward to the exchange. He said it's a 6 hour fix. That translates into a 6 day fix on my time. LOL
This page was generated in 0.067 seconds.
