WD-45 trottle
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 trottle
    Posted: 04 Mar 2015 at 3:23pm
I am a Wd-45 and am having trouble keeping the throttle in one place, it wants to speed up all the time. I have used wd40 on the linkage and it does not seem to help. Is there something that I need to change as a new spring or what. It does have factory power steering on it too if that will help with the answer. Thanks for any help Dave
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2015 at 3:57pm
There should be a spring on the back side of the quadrant that applies pressure to the throttle lever to keep it in place.  If this spring is broken or missing then that could be the issue. Wink
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2015 at 4:55pm
Thanks I will look , but I think that it is there maybe weak or broken.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2015 at 6:26pm
Might be time to replace the friction block that rides on the quadrant as it may be worn out.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2015 at 7:11pm
  you have a throttle spring undre the fuel tank---hooked on a bell crank it is either broke or missing have seen many replaced--- will cause throttle to creep
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 10:19am
Both of these things mentioned were problems on the WD I am working on, plus the holes in all the rod connection joints were worn out too, causing all kinds of slop in the system.
Just check everything from the hand control to the carb, for springs and wear. Bring that back into spec should help a lot.
