Clutch
Bobjones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobjones Quote  Post ReplyReply Direct Link To This Post Topic: Clutch
    Posted: 26 Feb 2015 at 5:22pm
Going to replace the main clutch on my 185 D. What is the difference between 4 and 6 pads.
screwloose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 5:57pm
Not much they both make you go. 4 has more bite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobjones Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 6:01pm
I am not pulling big loads. Smoothness of engagement is more important for me. Manoeuvering in tight areas.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 6:21pm
Then you would want the 6 pad. It's a smoother engagement and will last longer. I would also opt for a heavier pressure plate when doing clutch job.
This page was generated in 1.188 seconds.
