7060 clutch hanging up revisited
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: 7060 clutch hanging up revisited
    Posted: 20 Feb 2015 at 3:15pm
Couple weeks ago I asked on here about the clutch pedal on my black belly 7060 power shift hanging up. It did it this past spring and to be honest with you I don't remember what gear it was in when it acted up. I checked the return spring and it appears fine it seems to move smooth. Only thing I noticed is this seems worn I assume this is what kicks it from 5th or 6th gear down to 4th when you put the clutch in. Any thoughts folks
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2015 at 12:13pm
Bump
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2015 at 12:27pm
since there is no cable, check to see if BOTH springs -brake feel - and pedal return are present and ok, then check the bushing on the pedal by 70271518 rid or a bit on down the 70924121 yoke found on page 248 on 7060 at agcopartsbooks.com - enter as guest.
Something is no free - there are usually no tight fits here- all floppy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2015 at 2:58pm
Is 70272167 missing?
