ALLIS 200 brakes
nsummers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsummers Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS 200 brakes
    Posted: 14 Feb 2015 at 11:23am
I have an Allis 200 serial 200-4967 that had noticeable oil around the brake housing and brakes not tight so I pulled the cover to check. When I removed the bottom bolt on cover oil poured out. Upon removing the cover the brake assembly is all dry so my question is should that bolt hole be dry or does it go into the rear end cavity? If should be dry what's the cause? Thanks in advance!
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 3:47pm
The bolt hole is open to the final drive . If oil came out the bolt hole , then the final drive is over full of oil. cause could be oil seal on bull pinion or the cap on the inside axle bearing came off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsummers Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 5:39pm
Thanks Dave for your input. I noticed that the oil level was raised and wondered if that could be part of my issue. If I continue getting oil in my rear end is there a seal between it and my power director.
