Allis C brass main bearing washer
BlazerBuddy88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlazerBuddy88 Quote  Post ReplyReply Direct Link To This Post Topic: Allis C brass main bearing washer
    Posted: 10 Feb 2015 at 4:24pm
So in the proccess of tearing into the heart of my C I noticed that somsomeone had it apart already and had put M&W pistons in it and there were these brass washers under the main bearing caps. has anyone seen these before, are they factory and do they need to go back in when the motor goes back together.
hammer down and hope she holds
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2015 at 5:26pm
They are shims. These a factory equipment to get the correct bearing "crush". The procedure is explained in the service manual.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2015 at 5:34pm
The best thing to do is have your rods machined by an engine machine shop, without the shims, then you can forget about them. The rods should be machined at overhaul any way.
Back then the thinking was if you had a loose rod you could take out a shim and file a tiny bit off the crush edge of the bearing, and drive on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlazerBuddy88 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2015 at 7:21pm
Well the brass washers werent between the connecting rods only the mains. So the plan is to have the crank resurfaced and plastic guage the main bearings and the connecting rods and going from there with what bearing tolerance I need. I was curious if this was a homemade fix or factory.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2015 at 9:01pm
They were used at both locations, the main bearings and the rod bearings for the reason described. There were usually 4 on each side of the caps. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2015 at 9:17pm
 If somebody removed the shims to take up for wear, and you bolt up a new bearing and torque it down, you will most likely have scrapped your new bearing.
 The only way to know what needs to be in there is to bolt the cap on with things all cleaned up and measure the bore at 12 o'clock, 2 o'clock and 4 o'clock. All measurements have to be the same (with in a couple ten thousands of an inch) and the proper size for the bearing to ever hope to be round enough to fit the fresh crank.
Edited by CTuckerNWIL - 10 Feb 2015 at 9:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlazerBuddy88 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2015 at 11:18pm
Thanks thanks for the input Bob and CT, I was hoping not to have the block and bearings to be sent out to be machined and honned but sometimes gotta bite the bullet. Can you recommend any good machine shops in the northeast (lehigh valley) are of pa to have the work done at?
