Frost/Core Plugs in Shift Tower on WD
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Frost/Core Plugs in Shift Tower on WD
    Posted: 27 Mar 2010 at 10:08am
These plugs are in the cast shift tower on the tractor.  They plug the ends of bores on which there is shaft for the shifter forks to run on.
Has anyone found a source for these plugs?  They are approx 0.83 inches in diameter.
Thanks in advance for the help,
Terry
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 6:36pm
I am sure we keep in stock.
Dean Ag 800-589-2426
E Clark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Clark Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 6:56pm
I got them from an AGCO dealer. if the bag is still in the trash I could get the part # for you.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 8:32pm
  WE USE THEM OVER AN OVER  NO PROBLEM EITHER  DEALERS HAVE DONE IT FOR YEARS
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 6:22am
Thanks guys.  Our local Napa store wasn't too helpful...I had already tried that.  I checked the Agcoparts website and see they are listed.  I should have done that first.  As I am a Cat employee, I will give Dean Cat a call on Monday and give them some business. :-)
