Top dead center
dfh9036 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfh9036 Quote  Post ReplyReply Direct Link To This Post Topic: Top dead center
    Posted: 15 Oct 2020 at 10:40pm
Please bear with me on this question. I am trying to find top dead center for cylinders  1 and 4 on the engine in my D15 Series II. I need to adjust the valves.  I see the mark on the flywheel that says “Center” . Where do I go from there? Greatly appreciate any words of wisdom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 4:40am
Easy way is to remove spark plug, and stick a pencil, or wooden dowel down the hole, rotate the crank by hand, till the piston rises no more.
Also, the center mark on the flywheel should be in the center of the window, on the torque housing, right side of tractor...Wink
Edited by DiyDave - 16 Oct 2020 at 4:42am
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 6:33am
(CENTER) is Top Dead Center without the top dead.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 7:29am
When exhaust closes and intake starts to open on #4, #1 is at TDC. Same with #2 and 3.                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfh9036 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 9:22pm
Thanks for the words of advice. I appreciate everyone’s input. Will work on it this weekend. Hope to get it up and running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 9:40pm
When it is at top dead center two valves on one of the cylinders are closed and can be set at that point. That means the rocker arms are up as high as they can get with both valves sealed tight ready to fire or ready for the gap to be set. You can follow the firing order each revolution as the TDC line is in the center of the inspection hole to set the gaps.  I was taught back in the 1950's to set the valve gap one cylinder at a time as well as find the firing order of any engine this way.
Edited by Dick L - 16 Oct 2020 at 9:40pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 10:21pm
Dick, I'm with you.        MACK
This page was generated in 0.067 seconds.
