Tires- Bar (Ag) vs. Rib
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Topic: Tires- Bar (Ag) vs. Rib
    Posted: 08 Jul 2019 at 2:00pm
I've got a Massey Ferguson that I use for brush hogging.  Had the 2 rib front steering tires but they tend to not grab (slides across the ground) when turning despite having 600 lbs of weight upfront.  Was thinking of switching over to a Bar type AG tire to see if it wouldn't grab better and maybe even be less prone to puncture (at least on the bar part).  It's not 4 whl drive so not going to be any benefit there.
Anyone have any thoughts?  Tire shop telling me it won't make any difference......
D17 Series 1
Allis B- 1939
Allis B- 1945
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 4:29pm
I have 12.5 X 15 bar/tractor tread tires on the front of my Oliver 1365 loader tractor
they will steer better than triribs or other conventional front tires in my opinion.The reason I put them on was because they were 12 ply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 5:34pm
I wonder if mounting them backwards would make any difference?  (like a ground drive manure spreader)Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 5:56pm
Tire shop said to mount then backwards for less wear
D17 Series 1
Allis B- 1939
Allis B- 1945
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 6:34pm
…but they also said it wouldn't make a difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 7:04pm
Well now, that’s what I was thinking. But I think what he was implying is that the “bars” will wear down quicker then a rib tire......but that ‘wear’ has to be driven by something.....
D17 Series 1
Allis B- 1939
Allis B- 1945
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 7:08pm
that's what steering brakes are for .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 8:38pm
Gets pretty expensive driving with the brakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 8:52pm
I would think a regular 3 rib, would do better than a 2 rib. 3 ribs have most of the weight on the center rib, so more lbs per square inch of surface contact.
 I use my brakes when needed for steering, which happens if I'm going uphill with my little Massey and have the mower raised up.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 9:43pm
Four rib tires have been working on my tractors for decades, though they haven't been worked in fields for ten years.
Gerald J.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 10:04pm
I don't see how anything could beat tri-ribs for steering on a 2-wheel drive tractor, as long as you aren't in mud. That center rib is going to dig in better than a bar tread.
I'd say bar tread may work better in mud. They will work better mounted "backwards" in mud.
