Tire Chains - Front?
bendts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Topic: Tire Chains - Front?
    Posted: 24 Dec 2020 at 2:42pm
I have a set of chains for the rear tires, but will it help at all to put a set on the front tires even though its only 2wd?
Was thinking it would stop or minimize the plowing while turning in snow.
For a D17
1960 D17 Gas # 28849
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 5:01pm
Possibly although I haven't ever tried it. Chains and fluid in the back tires plus well adjusted brakes has gotten me by for 50 years .I use the wheel brakes to steer in deep snow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 7:12pm
I'm envisioning the chains rubbing against each other at the bottom and rubbing on the pedestal at the top.  Turn your tires inside out I guess.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 7:16pm
Do your "steering" brakes work ??
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 8:50pm
"Was thinking it would stop or minimize the plowing while turning in snow."
That is what separate brake pedals are for.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 9:31pm
As long as there is clearance for them, it sounds like a great idea. The V-bar chains would give good traction. Would help a lot when "angle" plowing. Incidentally, the other use for separate brake pedals is to provide a sorta "human controlled positraction.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2020 at 12:19am
I highly dought it front chains on my jeep didn't help a bit in turning unless 4wd was engaged. In 2wd the plow pushed it just as bad as without. Soon as I engaged 4wd the front changes did wonders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2020 at 6:33am
OK - Thanks.  Yes the brakes will work that way too, but was just just wondering if anyone had tried it, but it looks like weight and brakes are the way.  I may look for some on sale car/suv tire cables just to try.
