Three year old Ford Expedition
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Three year old Ford Expedition
    Posted: 09 Jan 2026 at 6:48am
Good friend of ours and I were speaking last night as mentioned blower motor, he noted replaced there old Expedition with a newer one a little over year and half ago. Got thru a close by dealer and was one of the Ford Certified used cars, 1 year warranty as bought. The wife was driving it and all the Aux functions quit, radio, windows, dis have wipers on and working but would not shut off. So to a repair shop as no warranty remaining.
Came to find out the electrical system is split into TWO Separate bodies, engine/drivetrain and what can be considered Accesoiries, has TWO Batteries, Separated Charging Circuits thru a special Module where charges each battery separately, accessory battery was not accepting a recharge where was getting a charge value, replaced battery and all was good again for two weeks. Repeated. So replaced module ar Ford, again not warranty, $488, as well new battery was drained and would not recover so took back to first shop that replaced NC. So far seems good and been a couple months. He is now gunshy of it. Been explained are SEVENTEEN separate modules in their car. Charging Module one of the least expensive and known failure point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2026 at 8:30am
Related same to guy I received KW from, he has a newer Jeep, Same, TWO Batteries and independent charge system, his New F550 Diesel THREE Batteries and closer to THIRTY Modules, he is going to trade out ANNUALLY to Semi Annually to keep Warranty and functions as see this even in OTR Semi Trucks.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 8:39am
Crazy. Hard to understand why these manufacturers want to make things so complex. No need for two batteries in a vehicle like that.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 10:29am
Its gotten Fricken nuts,,,, Ive never believed in buying new,, but if it keeps it under warranty- and they stand behind it, probably how Ill go,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 10:59am
Two batteries takes Parasite load off the Start System battery and keeps it off the machine to be able to drive after short but longer than normal parked durations was what I was told.  The Onboard Control Modules for all the Enter/Info-tainment systems up links and reloads all the time, unless add a battery isolator and reprogram every return to power or add a plugin battery charger to be plugged in for longer durations it is what it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 11:54am
gee every EV has TWO batteries......THAT is like, um, totally STUPID !!!
Wife's NISSAN 'only' has 8 computers.. the remote start one crapped out, so car could be driven without the key . NISSAN 'experts' couldn't find the problem after 3 tows to 'best dealership in Hamilton, wall of diplomas of the 'factory trained and certified' techs......
...in the end I READ some NISSAN  papers, and my $5 homebuilt 'scanner' SAW the problem module.
Idiots......
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 8:00pm
And there are many here that make fun of me driving my pre computer vehicles and I should join the modern world. NO WAY. everything I own is paid for and can be diagnosed the old school way: Past knowledge and experience.  99% of issues can be fixed on the side of the road with simple tools enough to get home, and with common preventive maintenance even that is rarely an issue to be concerned about. My FULLY mechanical diesels with manual transmissions, if they can roll, be pushed or towed enough to turn over will run with no electric whatsoever.
  With the high rate of sensor failures I hear about does everyone carry a full complement of sensors in all of their vehicles?
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 49 minutes ago at 11:17am
And the new OEM batteries are junk! A few months ago I replaced the battery for the 4th time in my 2019 RAM with an aftermarket one, the first 3 were MOPAR brand and were covered under warranty with the 3yr/36,000 mile warranty. The last one still had the battery warranty, but because it was replaced under the vehicle warranty the battery replacement warranty didn't apply.
Then my wife's 2023 Nissan, factory battery went bad 2 weeks before the "bumper to bumper" warranty ran out and was replaced for free. Got lucky on that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 44 minutes ago at 4:22am
All US Batteries constructed here are crap, the lead is almost strictly recycled and not sure why that goes to Hell in a handbasket but does.
Recycling occurs at Doe Run site mid Missouri where some lead is still mined. Recovered batteries are broken up and the lead cells acid and plastic materials separated then the lead removed from cell plates and blended with fresh mined. Some type of unidentified contaminate remains and reduces life.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 50 minutes ago at 5:16am
For the past 20 or so years in cars and pickups, I've had the best success with Farm & Fleet "Platinum" series batteries. I always get seven full, and most times up to eight years from them in automotive use. Usually Interstate group 31 in the trucks whether top, or threaded posts. 4D series are being rotated through and moving to the group 31 series as both lighter, and seemingly just as powerful in the engine cranking scenario.
That's All Folks!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 18 minutes ago at 7:48am
When I can afford it I buy Motorcraft batteries. I’ve gotten good longevity/ service from them and they have a good warranty which I haven’t needed but it’s there just in case.
Group 31’s from Auto Value for the Big Allis, but am not impressed. I’ve got plan B in mind for that, we’ll see what happens when I get the old girl back in service. Have a small tractor that was weak starting and then when temperatures got to zero she was done. There was an Auto Value battery in it and I was absolutely shocked and amazed that it was 9 1/2 years old!!!
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 54 minutes ago at 9:12am
I honestly think it's luck of the draw when it comes to batteries. We have a 2015 ecodiesel that still has the original batteries in it and so does my wife's 2016 chrysler. Have a 2005 blazer that had 3 batteries put in it in the first few years but it's current one is at least 8 years old. Tractors, big trucks, and pretty much everything that sits for longer have battery disconnects installed. I read a story a week or so ago about a guy who drove an old chevy pickup to work everyday for something like 37 years. I think it was a 1957 model that he bought for $75 when he started his job. He figured that he put 300 thousands miles on it during that time and only spent about $1000 in repairs. He kept it for a few years after he retired but eventually sold it to a grandson of the man he bought it from for the same money, $75. Looking at the repair costs and expected longevity of today's vehicles that seems almost unbelievable.
