Thought this was really cool
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 5:42pm
Originally posted by michaelwis michaelwis wrote:
My take  having purchased a brand new 7040  in 75 , and looking back .. there sure would have been  a lot of changes with that cab , if  i were the engineer ..
I had worked for AC from 1966 to 1969 and then went to MM when AC closed the La Crosse plant (didn't want to move to La Porte, Indiana).  I still remember heading for the big AC display at the Minnesota State Fair to see their new tractors.  When I climbed into the cab, I couldn't believe that they put such a phone booth on the tractor and provided such poor steps.  I was in my early 30's, pretty agile, and weighed 175 lbs.  I couldn't help but think about how hard it would be for a 220 lb, 50-60 year old farmer to get in and out.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 5:52pm
An 8000 series cab is definitely a start of the art design for its time, although I have never minded the 7000 series cab, espcially the newer version.  They are no worse than a JD soundgaurd cab, and are by far better than the 86 and 88 series IH cabs with the bassackwards doors.   Just my 2 cents.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 10:50am
Originally posted by daughter#1 daughter#1 wrote:
A friend of ours is a Moline man and has had both the a4t and the  4-150,  Liked to run both of them, but of course the 4-150 was favored.  He now runs fendt, and jcb tractors his first was a g1000 which he still has.  P.S. were you invloved with the project to put an allis motor in an a4t ???
I've heard back from the former AC proving ground chief engineer.  He remembers them getting an A4T for a "competitor evaluation," but not ever re-powering it.  The A4T's were the first articulated tractor from a major tractor manufacturer and one was probably looked at as part of the lead-in to the 8550 design.  To bad the 8550 engineers didn't pick-up on the articulation joint being centered over the middle of the drive-shafts.  A lot of CV joint problems would have been eliminated and the frame wouldn't have had to be redesigned for the 4W tractors.
If there is/was ever an A4T with an Allis engine, some privateer did it.  The first A4T's only had a 110 PTO hp MM engine in them and were grossly underpowered for their size and weight.  That could have lead to someone re-powering the tractor.
Mark
GTH-L Simplicity
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 11:51am
I thought the black belly 7000 series was about the best looking tractor out there. Maroon belly isn't quite as good looking. The only complaint I'd have is the maroon belly tracors should have had better steps but after market steps could have been had easily also the 7050 & 7030 didn't have a grab handle on the outside. I also like the looks of the 190 - 200. I've always like their looks. The 8000 series had to grow on me for looks. My Dad says the 7000 series looks had to grow on him. He thought they looked too much like a 20 series Deere. The 7000 series were being designed probably the same time as the 200 and I don't think the 200 had a whole lot of designing to it cause most of it already came from the 190.
I'll tell you this, I love my 7050 and the 190s.
Wink
I am a Russian Bot
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 12:25pm
Dad questions me why, but I'll take the 7080 over the 8070 on the graincart. I like the smaller cab for that job. It gives me far better view out sideways because the windows taper in at the top. Also there is no roof overhang. The 8070 has a cab post right where I need to see while the 7080's post is farther ahead giving me a larger rear side window. If  only the 7080 had PS, FWA, and 516 N7 engine,-----WOW.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 2:37pm
Interesting observation.  Back when the 8000's were being designed, there weren't a lot of grain carts in use.  The goals for the 8000 cab included easy entry/exit, spacious enough for a "trainer" in the cab, 2 doors, and air conditioning that was good in the Southwest as well as the corn belt.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 3:43pm
I'll give credit to whoever put an air cylinder on the 8000 series door. Name one guy who has run a 7000 series that has "NOT" felt the shoting pain of a door swings closed and hitting them in their side. That will make you say words that your mother thought you didn't know.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:15pm
I have my uncle's 1070 Case with #70 loader which he bought new in 1976. It was our first cabbed tractor with heat and air. New, the loudest sound was the heater blower in the cab even plowing. Not now after several years, though! But it is much harder to crawl into and out of gracefully after back surgery last fall!!! My Oliver 1855 was the easiest to mount and dismount cause the door was better positioned to the steps and you could get in and out either side!
This page was generated in 0.077 seconds.
