thinking of Running chaff spreader off combine hyd
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Topic: thinking of Running chaff spreader off combine hyd
    Posted: 07 Dec 2011 at 5:51pm
The L2 we have has a Vitetoe chaff spreader driven off of the header hydraulic reel drive.  We're looking at a bigger header and keeping the smaller one for small patches and was wondering about running the chaff spreader off the main hydraulic system of the combine rather than re plumbing the new head..
We have an old L2 for parts and i was thinking of putting a solenoid valve that engages with the separator clutch either in front or behind the main valve stack.  the only problem i see with after the main stack is that when the header is raised all the oil will be diverted to the one way cylinder and not return out the back of the valve stack and then to the spreader.
If it's in front, it will see the same pressure that it takes to operate all the other hydraulics of the machine.  It probably won't hurt anything but would be unnecessary.
thought about using the steering circuit but only runs 4 gpm, spreader needs 6.  both reel drive and main circuit on machine run 10.
has anyone tried this or have any other thoughts?
thanks,
Derek
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 8:04pm
bump
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 8:17pm
we always run the spreader off the main hydros, just buy an adjustable regulater to slow it down, if you run the full 10gpm then it will just spin it faster.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 9:09pm
Call the spreader inc for info. 217-568-7219. We may have a kit on hand!
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 9:29pm
Had a Vivitoe (sp?) on a JD 8820 it had a regulator so you could adjust the rpms = spread width.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 9:57pm
The L2 does not have a hydraulic seperator clutch, it is a electric clutch. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 10:02pm
I already have a flow divider that i plan to put in, just wondering if you put the valve on the back side of the main stack or in front.
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 10:26pm
I plumbed one thru the steering circuit on a 79 L2 and customer thought it was just fine....he only had 15 ft wide headers and it ran whenever the engine ran, which he was fine with that as far as safety goes.
This page was generated in 0.178 seconds.
