the first one I have ever seen |
Page 12> |
| Author | ||
Rick143
Joined: 13 Dec 2015 Location: Lomira, WI Points: 247 |
Topic: the first one I have ever seenPosted: 28 Nov 2016 at 6:45pm |
Allis Chalmers corn chopper.
http://madison.craigslist.org/grd/5890019100.html |
| Sponsored Links | ||
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 28 Nov 2016 at 6:55pm |
I ran one for a bit this summer. They have a bad reputation, since the crop has to go up, then turn, kinda by itself. If everything isn't super shined up, they just plug up.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2584 |
Posted: 28 Nov 2016 at 8:09pm |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4573 |
Posted: 28 Nov 2016 at 8:58pm |
My Dad bought an A-C chopper like that in 1953
MACK
Posted: 28 Nov 2016 at 9:03pm |
They were a good chopper in their day. MACK
FloydKS
Joined: 12 Sep 2009 Location: S E Kansas Points: 8463 |
Posted: 29 Nov 2016 at 6:49am |
Yep, we filled 2 silos (30 feet high) every year with corn.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5909 |
Posted: 29 Nov 2016 at 6:58am |
AND you could remove the 'corn head' and install the 'grass attachment'
( like a 'Combine' header ) to chop hay. Gary < ="" ="text/">setTimeout("waitForPageRender()",5000);
JarrodACFan
Joined: 24 Jan 2012 Location: Delaware Co. IN Points: 732 |
Posted: 29 Nov 2016 at 7:37am |
We've got one with the grass head. Great grandpa bought it new in the late 40s/early 50s and never needed a corn head. It is in pretty good shape as far as I know, but it hasn't been used in probably 40 years.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN |
Joe Graunke
Joined: 14 Sep 2009 Location: Clayton WI Points: 659 |
Posted: 29 Nov 2016 at 9:19am |
I've got 8 of them. I'm trying to figure out how to get corn through them better.
Joe |
Joe Graunke
Posted: 29 Nov 2016 at 9:21am |
I hope we can get to work this coming June! Joe |
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 29 Nov 2016 at 9:57am |
My dad had 3 at one time, one of them was bought new and was our first chopper. It seemed that the corn was either too tall or too short for it to work right. We spent a lot of time "walking the plank" to unplug the dang thing...no wonder they put a hinged cover on it LOL. We even had the dealer put the update kit on it which was a couple more rollers on the bottom to try to get it to feed better. Another problem was most of the material was cut in one area of the knives, so when you used the on-board sharpener you had to grind down the edges to get the worn spot in the middle sharpened...took a lot of time. The sickle drive was also a problem, not a good design. Gehl and New Holland made much better machines....
ALLIS EXPRESS!
This year: |
TimNearFortWorth
Posted: 29 Nov 2016 at 11:32am |
Called em' "man killers" when I was a kid and uncle was hurt pretty bad messing around with one plugged up on a hopped up WD45 in 1959. He became an A-C dealer couple years later and would not take one on trade or even carry parts for them.
JimIA
Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1984 |
Posted: 29 Nov 2016 at 5:37pm |
Like most machines people have a love hate relationship with these. My Grandfather bought one in the late 50s with both the windrow pickup head and the corn head. We switched heads until the mid 80s when we bought a second chopper with a corn head and just used the two individually. I was lucky to be too young with the head exchange. The hay head machine was used for three crops of dry hay plus straw to be blown up in the barn. We used that machine until 1995 when we got a 770 New Holland. The corn head machine was used until somewhere around 1990 when we got a 707 New Holland. Although the 707 made a good product I liked the A-C better. Had better capacity and plugged less. We never really had much for feeding problems other than the first load was always a bit of a bear. The later machines had adjustments on the axles to raise or lower the unit. That can help with feeding. Also removing or adding the spring helps, I have had luck changing the head speed as well. The last few years we chopped we used a 780 AC. That corn head didn't feed the greatest either. One year we had to chop the neighbors at one row at a time because we couldn't get it to feed with two. Some people didn't like them because they didn't chop the corn leaves up the finest either, when the 50 offered the six knife option that helped things out. I laughed a few years ago when a dairy feed specialist told me that a longer leaf corn silage is better for the cows digestion ending in a lesser chance of a twisted stomach.
All in all the chopper had plenty of great designs too. We really didn't see much capacity change when we went from using the D17 and the A-C to the 190 with the New Holland 770. With the 707 we went backwards in capacity. The wide cylinder spread the material evenly over the three foot wide cylinder taking a lot less horsepower. One memory I have is at our local show I was chopping some corn with my 1953 WD, the person planted the corn and didn't cultivate it, I ended up chopping two rows at once that were full sized ears and 12 inches apart. It was a good growing season, the WD just barked and took both rows. Setting up the shear bar is really easy also, the cylinder was on an eccentric, with a wrench and hammer you can set the shear bar in minutes. To sharpen was a very easy task also. We still have both of our machines as well as a 50 and a couple 780s. AC built a decent number of them and I used to see a decent number of them around. I have bought and sold a couple and parted out 3 of them. Jim |
Carl(NWWI)
Posted: 29 Nov 2016 at 6:37pm |
Heck, after reading that Jim makes me want to try and get the bugs worked out of mine. I think if I could've chopped drier corn it would've went alot better. It was 60-70% moisture corn, and went it plugged my hands would be soaking wet after cleaning it out. But when your filling silo for dairy's cows you are at the mercy of what needs to go in the silo. I should've tried again in a few weeks and fed it to my buddies beef cattle. Oh well, there's always next year.
HaroldOmaha
Posted: 29 Nov 2016 at 6:59pm |
We had one when I was 14, in 1954. Dad ran the chopper, and I set up the blower and did the
unloading. when the neighbors saw how fast we could fill a 12-14 x 30 silo. We got more requests than we had time.The man that hired us to chop his corn hauled the wagons to the silo and helped me unload. we had 3 faults front wagons. Filled the silo in one day, and topped it off the next day, plus do our own chores at home. Then move on to the next. It sure beat those IH, Papec rotary choppers. They had to remove their blades and take them to be sharpened. As to the Allis cylinder chopper we sharpened them on a regular timing so we didn't have any unusual deep worn spots. One year we grew sorghum in a new swamp area that was on a dry cycle. It grew so tall(12') we had to raise the reel on the grass attachment to reach it. The gas WD45 didn't have enough poop to run it. The dealer brought out the New WD45D to run the chopper. Harold
HD6GTOM
Posted: 29 Nov 2016 at 8:19pm |
We started out with the chopping crew in the middle 1950's. They used 1. Don't remember having any plugging problems. Neighbor pulled it with a WD 45.
CrestonM
Posted: 29 Nov 2016 at 8:36pm |
We'll need a wire wheel and a few 5 gallon buckets of graphite LOL!
CrestonM
Posted: 29 Nov 2016 at 8:40pm |
8??? Lol! Gonna hook them in tandem behind a D21? Lol
HaroldOmaha
Posted: 29 Nov 2016 at 8:47pm |
I was just thinking, people have mentioned that older corn shellers and older combines have a problem working in the new corn and bean populations because they can't consume the product fast enough. Maybe this is the problem with the choppers, because they weren't made for the volume of the high populations . Slow down, they may work right.
Harold
CrestonM
Posted: 29 Nov 2016 at 9:02pm |
Our problem was the chopper was very rusty. Run 1 or 2 stalks through it, and it plugged. It needs a really good manual shining, and I'm sure it will be better.
caledonian
Silver Level Access
Posted: 30 Nov 2016 at 11:37am |
I agree with JIMIA. Dad bought one in about 1955 or 56. Used it on a straight WD first than later a D17 And finally a 180D. They took less horse power than some other makes. In a lot of ways were ahead of their time. Used it until about 1982 when we got a 782 new Holland. The Allis always seem to work well for us. The heaver the crop the slower you went. But that was expected. The New Holland took a lot more HP in comparison.
JimIA
Posted: 01 Dec 2016 at 5:31pm |
I just remembered a story a friend of mine told me. His Dad had one of these choppers and was chopping some tough hay with it to go in a silo. Somehow the smooth roll got wrapped up with material and the machine caught on fire. With nothing else in sight to use to put out the fire the farmer jumped on top of the chopper and urinated on the fire! As I always say, use whatever works!
Jim |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12327 |
Posted: 02 Dec 2016 at 5:25am |
Boy Jim, now that's performing under pressure!
Or is that having the pressure to perform? Edited by Tbone95 - 02 Dec 2016 at 5:58am |
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 999 |
Posted: 02 Dec 2016 at 6:58am |
I put an engine fire out on a K Gleaner the same way....
Life is simpler when you plow around the stump.
Tbone95
Posted: 02 Dec 2016 at 7:02am |
Sheesh! Good thing it wasn't an electrical fire, huh?! I'm one of those that has stage fright at a crowded place....not sure I could put out a fire on demand! Now, if I were drinking Bud Light while I was combinin', that would be a different story. That chit multiplies. Gozouta = 1.5 x Gozinta |
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1141 |
Posted: 02 Dec 2016 at 4:03pm |
Picture is from Hutchinson 2015. They were trying to blow a little to wet alfalfa in that wagon. It was nice to watch for a few minutes. I liked your story Jim.
CrestonM
Posted: 02 Dec 2016 at 4:33pm |
I remember that very well! Go 10 ', then plug. Clean out. Go 10 more feet, plug again. Lol!
Joe Graunke
Posted: 02 Dec 2016 at 9:35pm |
Cody and me got the bugs worked out! |
CrestonM
Posted: 02 Dec 2016 at 9:41pm |
Too bad I don't have the video! That was the first part of the field demos I ever saw in person (It was my 1st year) and when I saw them out there plugging the chopper over and over, I thought..."So....this is how the field demos work...???" LOL
Joe Graunke
Posted: 02 Dec 2016 at 9:57pm |
That was our first year trying the new side delivery spout. A person learns a lot over time.
Page 12> |
