The Dollar Bill Test
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Topic: The Dollar Bill Test
    Posted: 01 Sep 2012 at 6:44am
I replied to a forum question that need greater explanation, I thought it would be a good post on it's own:
I learned this from a buddy about 30 years ago, when I would try to buy old Jeeps that had 4 cylinder engines and I used it when I bought my  WD45 tractor with a 4 cylinder engine. You start the engine at idle or 1/4 throttle, with a firm grip, place a new 1 dollar bill  about 2" over the exhaust pipe, as the engine is running if it sucks the dollar bill into the exhaust, it will snap like you can't believe. I was told that this is a sign the  exhaust valve is  sticking or the seat is bad, it could also be bent, burnt or out of adjustment too. Here is a video from youtube that shows no problems with the valves http://www.youtube.com/watch?v=l8LRhuHuerw sorry I could not find a video of it sucking in the dollar bill, my friend sold his ford tractor that did this last year. Here is another link to this test scroll down to shop tip http://books.google.com/books?id=Yn9F0RhJ0EkC&pg=PA573&lpg=PA573&dq=dollar+bill+exhaust+valve+test&source=bl&ots=S9F4AHOCyc&sig=o6U4jNIctW4upR1VjJqCyqTAMEk&hl=en#v=onepage&q=dollar%20bill%20exhaust%20valve%20test&f=false
Danny
Edited by dannyraddatz - 01 Sep 2012 at 7:38am
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 4:33pm
Used that tip for years. Works on small engines also. Tracy Martin
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 5:29pm
Live near town of Forest City N C . It has so many used car dealers they call it Little DeTroit.  That trick of the dollar bill has been around a long time and been used a lot in this area . Had to use a one dollar cause that was only kind people had .
