tap for exhaust manifold
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: tap for exhaust manifold
    Posted: Yesterday at 7:34am
OK, trying to clean up the garage and found some big taps, got me thinking, pretty sure some here posted what size tap can be used for threading the exhaust manifold on a D-14 or maybe a B ?
I just hate to toss out these taps IF that can be used by someone.
Jay
update. finally found one of them, says 2" , 1 1/2 NPT. Has 2-3 missing teeth otherwise in VGC !
Edited by jaybmiller - Yesterday at 3:37pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:44am
Not sure about a 14 but a D-17 takes a 1&1/2" pipe tap.
I don't scrap a tap until it's broken generally speaking. Don't tap enough holes to make one dull these days.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:34am
I bought a 1-1/4" pipe tap specifically for my Model C manifolds, works great!
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:37pm
1 1/2" npt on D17 S3 gas.
 2" npt on AC 180 / 185. IHC M- 560 gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:56pm
keep them around.. those come in handy when working on OLD PLUMBING drains... also bilge pump - irrigation pumps suction and discharge ports.. old rusty  pump cases can be repaired..
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:15pm
Can a D12 III manifold be tapped? I haven’t had much luck with the original setup. The muffler stabs into the manifold and has two bolts that bolt thru a flange on the side (for lack of a better term) into the manifold. If it can be threaded and a pipe nipple screwed into it I could secure a muffler with a muffler clamp
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 2 minutes ago at 6:36am
I would think they could be. You would have to check the I.D. and see if it's close to tap-drill size. It might be interesting trying to cut threads into cast iron that has been heat cycled a zillion times.
