styled wc speed patrol |
firecowallis ![]() Orange Level ![]() Joined: 16 Mar 2012 Location: Helenville Wi Points: 464 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Mar 2012 at 8:54pm |
what is a good running styled wc speed patrol worth
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
What shape are the tires? Is it original or has it been converted to hydraulic? Is the front end bolted or welded on? Does it have the serial # tag? Could be from $2500-$4000 maybe to the right person in the right condition.
needs tires orig paint welded front not converted to hydralic
thank you for any and all help
serial no is 1e 1289
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
What dose the guy want !!!!!
Rfdeere ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
When did the W patrol switch from bolted to welded ?
Edited by Rfdeere - 17 Mar 2012 at 5:42pm |
http://www.rumelyallis.com |
The ones built in LaPorte thru 1942 were bolt on and from 1945 until the end they were welded on and built in the Spingfield plant.
dustinmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
I believe after they went back into production following ww2 but I could be wrong, we have a 41 and a 46 the 41 has bolts and the 46 is welded and I dont brlieve they were made during the war
Thanks ! I was thinking that.
