Straw Walker Blocks - lubricant recommendation? |
Meanolallis
Topic: Straw Walker Blocks - lubricant recommendation?Posted: 26 Sep 2016 at 9:48am |
I'm putting a set of new (oiled wood) straw walker blocks in an F3. Does anyone have a recommendation for any additional lubricant that I should put on them before installation? I was thinking either motor oil or some planter graphite, but maybe I should just install them "dry"?
Any suggestions? Thank you! Peter
jorstad brothers
Posted: 26 Sep 2016 at 10:08am |
lard, beef tallow works really good on walker blocks.
remember plunder than burn
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 26 Sep 2016 at 12:34pm |
Do you not have to lube them occasionally after installation, if you're lubing them now?
Meanolallis
Posted: 26 Sep 2016 at 12:36pm |
I think they're intended to run without lubrication, but was just looking for something to put on them from the start. Beef tallow/lard seems like a good idea.
Ron(AB)
Posted: 26 Sep 2016 at 9:50pm |
I think they develop a polish once you run them and that should make them maintenance free.
We never oiled ours, but we keep it in the shed. |
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 27 Sep 2016 at 8:44am |
I have seen some with a grease zerk mounted in the blocks. when I put new ones on I always just slimed a little with my finger on the inside...just a film of grease
shameless (ne)
Posted: 27 Sep 2016 at 8:45am |
make sure when you tighten the bolts, that the blocks are not tight on the crank, you'll break the chain. you may hafta put a few paper bushings in them.
Lonn
Posted: 27 Sep 2016 at 8:46am |
They should turn over by hand.
Wink I am a Russian Bot |
combinechris
Joined: 20 Jul 2015 Location: wittenberg,Wi. Points: 424 |
Posted: 27 Sep 2016 at 11:25am |
I use STP oil treatment. The really thick stuff in the blue bottle.
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
1terrygladys
Posted: 27 Sep 2016 at 5:56pm |
The shaft augers on our old combine used to get to rattling in the blocks. I squirted silicone spray lubricant between the blocks and shafts. Quieted them right down.
WD-45, WD, Unstyled WC, SC Disk, JD 4430D, JD 4010D, JD B, Iowa pastor & disciple of Jesus Christ
