strange noise after stopping. fiat 645b
bjorn tore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bjorn tore Quote  Post ReplyReply Direct Link To This Post Topic: strange noise after stopping. fiat 645b
    Posted: 23 Mar 2023 at 11:18am
I have an Fiat allis 645b wheel loader.  I have been refilling some hydraulic oil because it was low on oil and it seemed like i had some air in the system.  But after refilling this it seems like the hydraulics works fine now. But after i stop the wheel loader i hear a whistle sound, its sounds like a tire that has a leak.  the sound comes from right under the cabin near the hydraulic pump. it disapears again 5 min after stop. Cant see any oil drops either underneath.
Does anybody know what this problem is ?
Edited by bjorn tore - 23 Mar 2023 at 11:19am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2023 at 11:20am
Pretty sure it has a compressor/air system for the brakes (both of mine do) so quite likely you're hearing an air leak from that.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2023 at 12:15pm
in addition to what Darrel said... i think the air brakes might bleed off and LOCK when the tractor is OFF... You start the motor and let it build up air pressure to RELEASE the brakes ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 9:52am
My 78 545B has air over hyd brakes. No air-no brakes. Has a drum parking brake on driveshaft with the over center lever. Mine has a dual air tank near the hyd pump with petcock drains as well as a large tank in the rt rear corner. Could be similar. I would pursue air leaks first.
