Steve's CA Knock
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Topic: Steve's CA Knock
    Posted: 22 Jan 2012 at 10:41am
Just thought I'd start my own thread on the above instead of further cluttering  Stewart's
I started the tear down and got some plastigauge but before going further I decided to check some measurements to permit a calculation of my compression ratio.
So I took off the head. It's a 3.4375" bore.
I CCed the head at 70cc (4.2716 cu.in.) and I sorta guesstimated the bore space above the piston including the gasket to be 4cc (.245 cu.in.) and the swept volume is 532.124cc (32.4722 cu.in.).
I got 8.287 to 1 compression. I then checked the piston top to block top and got about .032". I wondered if my overbore pistons were higher compression too.
Today I pulled a piston they're M&W "add power" pistons and compared it's height to a 3.375" piston I had and to my amazement it measured about 0.060" BELOW the stock piston.
The only reason I could think of for the lower height was to compensate for the increased swept volume of the overbore and subsequent increase in compression that would result.
But heck if they were "more power" pistons they woulda been even more at a higher compression.
I'd appreciate anyones thoughts and possibly corrections of the 8.25 to 1 compression figure that my figuring produced.
So I'm now doubting my comp. ratio calcs.
I'll redo my calculations and check back.
Steve
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 10:59am
Steve
Sent you a pm; my new Clevite stock pistons are "0.325 below the deck at TDC. I believe compression is determined by the distance between the wrist pin and the top of the piston. A longer dimension should have more compression than the shorter dimension.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 11:02am
8.25:1 would help make a pretty strong CA. Seems like original CR is in the 6.25:1 area?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 11:11am
OK folks,
I've re-done my calculations and I get 6.41 to 1 as the CR which sounds more reasonable.
The lower height of the M&W 3.4375" pistons must be calculated to keep the stock 6.5-1 CR.
I'll continue checking for my knock and pondering how to increase the CR before re-assembly.
More to follow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 12:14pm
If the M&W "add power" pistons were the same height, from the wrist pin, the compression ratio would have increased to 7.324-1 just on the swept volume increase. Too bad, I'd have liked that.
I can't really measure the  volume of the combustion chamber in a head milled, say .100" without actually doing it but I estimate the volume might decrease by,say, half the diameter of the bore or .464 cu.ins.
If  I subtract .464 cu. ins. from the chamber size my 6.41-1 goes up to 6.86-1 hardly worth the effort.
If i could machine the block I could get more but I'd have to pull the liners and then rebore the block for their lips.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 4:18pm
I would get taller pistons before I lowered the deck.  Most pistons for that engine are flush with the deck as in this picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 5:57pm
Thanks Dick,
Does anyone know where I could get taller 3.4375" Pistons?
But then I could also get the crank stroked  to bring my M&Ws up to the top of the block. Speaking of M&W pistons, I'd love to hear any more information about them.
I'll run the "even with the top of the block" numbers tomorrow when I'm a little sharper. At my age I start the day dull and it isn't long before I'm BLUNT.
Thanks all, for your thoughts and keep'em comin'.
Steve
Edited by SteveC(NS) - 22 Jan 2012 at 5:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 3:24pm
Just a little progress(?) note. After successfully milling my CA head 0.100" I decided to change the crank before reassembly ( I just happened to have a couple of reground cranks with bearing inserts).
 That done, pan back on I was ready to put the milled head on  it and in so doing I discovered that the long head bolts had to be shortened to compensate for the 100 thou removed from the thread. That done I checked the short head bolts and found their tapped holes in the block to be fine, no need to shorten them.
Dick L (et al) have you ever come accross the need to shorten the head bolts after milling a head?
I know this project seems to be dragging out but NOTHING gets done in a timely manner here.
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:04am
Steve,
I know what you say about getting things done in a timely fashion.  I tore apart my CA engine back in January, and just last night I finished putting the head, rocker arms, valve cover, and exhaust manifold back on.  But now I am putting a wide front on it.  I'm sure it will be quite some time until I get finished.  With field work and mowing the lawn, etc, it's hard to find enough time.  Glad to hear that you are making some progress.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 4:48pm
Stewart, glad to hear from someone else with too many irons in the fire.
It just seems to me that when I worked 40+ hrs. a week I got more done at home than now that I'm retired.
Anybody else ever have to shorten head bolts after milling the head?
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 8:25pm
You might want to check into shortening your pushrods as well.  I've had trouble in the past with binding rocker arms after milling a head.  Of course that was on a JD, but the same geometrical laws still apply I think.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 8:54pm
M & W pistons for the A-C models B, C, and CA were piston set SP-5. That number should be on the piston somewhere. They are 3-7/16" bore, and have 6.4 to 1 compression ratio versus the stock 6.2 to 1. M & W claimed observed belt horsepower of 29.7 versus the stock 25.9. dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:15am
Way-ta-go Dave, Now you come forth with M&W piston info, now that they're back in the block and the pan is on etc.
I guess I should have written down any and all of the numbers and identification.
Still, I can't figure how they could provide higher compression than the stock 3.375" pistons that came up higher in the bore??
Kinda tricky shortening the pushrods too.
Maybe a  shim under the the rocker brackets?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:25am
Steve
You can use gr8 washers under the long head bolts to eliminate shortening them. I have "shimmed" rocker arm supports using machine washers (long story about why I needed to do this, suffice it to say that the old timers were very ingenious on keeping these machines running) with good results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 2:39pm
The trouble with shimming rocker stands is that then you end up having trouble getting the valve cover to seal.  Sometimes you end up with two gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 8:03pm
Thanks Greg & Bret. I've already shortened the long head bolts on the lathe and re- torqued them  (one by one) when I get to cold gapping of the valves I'll see if I need to take any other measures.
I'll keep you informed ( at my normal rocket pace).
Thanks for the response.
Steve
