Steve@B&B
Chris View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Topic: Steve@B&B
    Posted: 26 Jun 2011 at 2:47pm
I am going to put a alternater on my WD-45 and iam going to switch it to a negative ground. Is there anything i have to have done to the starter to make this work? Or can it be used as is?
 Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 4:34pm
It will work just fine. Just keep her tuned up good so you don't end up cranking too long on the starter and over-heating it.. If she don't start in the first 10 seconds give it a minute or two to rest in between tries.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 6:57am
Charlie hit it right on the head. If the engine is in tune and fires right up immediately, you shouldn't have any starter issues unless the starter has issues before hand where components are pretty worn internally. If it does, sometimes the application of 12V's sends it to the toilet sooner. On occasions, it's good to make sure the Starter motor pinch bolt doesn't losen up allowing the Starter motor to move when appying 12 volts as you use the Tractor. An occasional shake of the motor to make sure its snug in its mounting cavity will save a possible nose cone issue or ring gear problem. The way the Starter motor is mounted is crude, especially when applying 12 volts to the unit. A good unit will make a lot of torque, and you can actually see em' move when cranking sometimes... HTH
