Starter Electrical Problem
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Starter Electrical Problem
    Posted: 20 Sep 2022 at 8:53pm
Working on an off color riding mower (anyone got an old Allis rider for sale?) and I’ve hit a wall. Problem was I could turn the key to start and you could hear the bendix engaging, but you’d have to turn the key off and back to start position a dozen times to get the starter to actually turn. Then it would crank fine. Recently everything quit. No solenoid clicking, even though battery is fully charged. Decided to take the starter off, which was a big chore in itself. Hooked jumper cables straight to the starter after I removed it and the bendix extends and the starter turns, every time I put power to it.
At the ends of the 2 starter wires, the battery cable has 12 volts, as does the solenoid wire whenever I turn the key to “start”. Every time. Tested it over a dozen times. When I hook the wires back to the starter, they both still have power when key is in “start” mode, and even with a dedicated ground wire on the starter (starter still removed from engine at this point) there is no response. I can’t figure out why it works fine when hooked direct to the battery but not when hooked to the wiring harness, even though it has 12 V going to it, and a dedicated ground wire running from the clean starter to the clean negative battery post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 9:16pm
Got a Simplicity Zero with similar issue. Has to be bad connection but haven't found it.....just keep twisting key. Know this. Just because you have 12V at the end of a wire doesn't meant the connection will carry the amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 9:26pm
YEP... solenoid is bad or one of the cables is rotted end on it.. Your getting 12 volts, but not enough amps to move the starter... jumper across the solenoid with  cable / pliers and see if it cranks..  check cable ends for corrosion... bad ground on strap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 9:34pm
I'm going to go take a better look at the ends of the cables tomorrow. Could be internal corrosion of the positive battery cable I suppose? I've seen it once before, but what causes that?
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 10:30pm
Go buy a new battery
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 6:32am
Corrosion up inside the positive cable put one of my tractors down for the count, and I sadly was not the one to figure it out!  Felt pretty stupid when the mechanic told me he put on a new batter cable!Ouch
As everyone said, you have a weak connection somewhere, showing power, but not carrying current.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 7:30am
Load tester shows it's good.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 7:32am
Get a set up jumpers and connect + to solenoid and starter lug from + battery.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 8:05am
I had one that it would quit running but if you was fast enough at wiggling the key it would keep running, replaced ingition and problem solved
Post Options Post Options   Thanks (1) Thanks(1)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 11:59am
Ended up replacing the positive cable as well as the key switch since the dealer had one on hand. The old cable did appear to have internal corrosion after I cut the end off to get a better cross section view. Back up and running now!
Thanks guys
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 12:26pm
Thanks for letting us know
