Square Baler Issues
powerwagon78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powerwagon78 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2015 at 10:15am
It looks to me like everything is working like it should.  I even tried slowing down the RPMs on the tractor, thinking maybe everything was running too fast.  No luck.  It's driving me crazy though....thanks again everyone for the help.
Allis Chalmers WD45 NF
Hesston PT10 Hay Mower
New Holland 269 Square Baler
Semper Fi
USMC 2001-2005 OIF I VET
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2015 at 10:49am
Your timing is off. That fact that you mentioned that your twine disks move twice in a knotting cycle tells me this. I suspect that the resting/starting position of your knotter is wrong.
Look here and go to knotter troubleshooting:
http://www.boonetractor.com/subpages/parts/squarebalerperformance.pdf
Is your knotter brake working correctly?
Edited by DougS - 11 Jul 2015 at 11:59am
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2015 at 4:13pm
The twine fingers should not move twice. There is a definite timing problem. Most  baler manuals have the systematic adjustment of the knotter. Follow that in order stated and your baler should tie. If I was closer I would come and look at it for free. Do you have a local baler mechanic that can look at it?
