spreading litter w/ 7080
SCPAAndy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCPAAndy Quote  Post ReplyReply Direct Link To This Post Topic: spreading litter w/ 7080
    Posted: 06 May 2010 at 6:27pm
Took a second today to snap a picture of the 7080 w/ my Hagedorn spreader applying some litter at the on farm this morning while it was still semi clean before going to spread dairy manure for a customer.  Still havent gotten a chance to put the duals on I got from RAiken but she sure does move.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 8:03pm
I'll bet you need that big 7080 to pull the load of well stuff around the field.
Nise looking tractor!
Don
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 8:17pm
Sweet tractor. Probably not so sweet aroma.
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 9:15pm
 WOW, looks great Andy! You could do restoration work when you have nothing else to do. Tell Dad I didn't forget, I will get the "rest of the story" someday...Harvey
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 11:19pm
How many ton in a load?  Do you really need that big of a tractor for that spreader?
ALLIS EXPRESS!
This year:
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 5:20am
How do you like the hagedorn spreader for manure?Some here had John Deere Hydrapush and did not like them.I always had Knight slinger spreader worked great except for pen packed.A spreader that big will work a 7080 just pulling it down the road also a big tractor does not bounce as bad on the road and stops better.I have seen farmers try to pull big spreaders with smaller tractors and have disasters like broken drawbars,rollovers, and being pulled off the road when getting over for on coming traffic.Manufaturer's are now require to put hydraulic brakes on the big spreaders for safety.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 5:22am
Looks like the spreader holds about 700 bu. struck.Tell us if I am correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 7:01am
After checking the Hagedorn website I find my estimate was off by 150bu. The spreader should hold 550bu. struck which is still a lot of weight,solid manure weighs approximately 77.4 lbs. to the bu. with the spreader holding 550 struck the weight of the manure would be 21.28 ton. my source is Iowa State University tips for spreader calibration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCPAAndy Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:25am
When hauling dry litter Weights are roughly 7-8 ton like what u see loaded now and for wetter pen pack 14-15 ton. As far as compared to side slingers there is no comparison- the hagedorn does a very even job and spreads anything from lime, litter, pen pack to very sloppy manure
Nathan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 9:10am
The knight side slingers are excellent machines. When it comes to hydra push spreaders I believe H&S builds the best one alot of little differences over other brands that make it easier to work on and alot less likely to have problems due to the placement of the drive gearboxes. Just my thoughts though.
35WC 37WC D-10 D-12 D-14 D-15 D-17series 1 (2)D-17IV D-19 CA RC Unstyled WF GLEANER E 416H 314H 712H 716H
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 9:25am
Is that a 3290 or 3440? or whatever the big one is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCPAAndy Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 10:08am
The website is out of date- this one is a 5290 the smaller if u can call it
that of the 2 vertical beater models. The thing I don't like about the side slingers is the spread pattern bc they don't spread as even and the augers will allow the pen pack to bridge up and not feed nice but to each his own- plus a 40' + spread pattern really covers acres quick
This page was generated in 0.093 seconds.
