Spin-out Cam Socket Wrench
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: Spin-out Cam Socket Wrench
    Posted: 18 Oct 2016 at 10:31am
My WD45 has the standard 1/2" square adjusters on the spin-out cams. I'm wondering what wrench or (preferably) socket is used to adjust them. I've been looking for some sockets designed for square bolt heads so I can get maximum "bite" on the cams, but I haven't found any thus far. I'd appreciate any suggestions for sources or alternative tools. [I've though about welding two 1/2" drive sockets together but am hoping for another idea!]
Thanks.
Dave
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 10:37am
Take 2 old sockets and put them face to face with the square ends out. Weld together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 10:39am
Most any place that sells good sockets will have 8 point sockets that will work. An impact socket would be best for this, having thicker sidewalls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 10:47am
Thanks! Appreciate both suggestions. :)
WC, CA, D14, WD45
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 11:20am
Square? Think all the eccentric cams I have are hex. I just use a 3/4 socket.
AaronSEIA
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 12:07pm
WD45 should have 3/4" hex cam bolts. Sounds like you have CA parts on yours.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 12:16pm
Yep.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 12:24pm
Now that is interesting! I surely didn't know that. Are the correct ones still available?
Made a tool as suggested above - will paint it AC #1. :)
Edited by Dave(inMA) - 18 Oct 2016 at 3:16pm
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 6:23pm
I've still got the shop built one I made for the D10 and 12.  Welded 2 impact grade extensions together, at the male ends...Hug
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 7:18pm
I've got a few sets of the correct ones, but they are all rusted solid.  Need to free them up.
AaronSEIA
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 9:22pm
The CA used the square head adjusters and the WD had hex head adjusters. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 9:43pm
CA Had 3 lockers and one hanger. WD,WD-45 has 4 lockers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 7:06am
Tried my tool - I was able to tighten all the CA-style 'lockers' - 4 on each rim and also a 'stopper'. :) But the tractor is suffering from low self-esteem since it has the wrong locks!! I'll be watching for the proper ones.
WC, CA, D14, WD45
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 7:24am
What size tires/rims do you have on your WD45?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 12:15pm
Hi Don. The tires are 13.6x28, marked as replacements for 12x28. The rims are (probably) 12x28, but I don't have a good way to measure the width except that the tire sidewalls seem to be in nearly the same plane as their beads.
WC, CA, D14, WD45
This page was generated in 0.071 seconds.
