Speaking of Gleaner E's
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: Speaking of Gleaner E's
    Posted: 26 Sep 2020 at 11:37am
The E is not the easiest to switch from corn head to grain head. Anyone have any tips to make the job a little easier next time?
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 1:26pm
There is a crib that the grain head is to be set on when not on combine. It holds the cutter bar up a little to help the top hooks get started. I built mine on casters to roll around shed. A little practice and they aren’t an issue without. I unhook mine on the goose neck trailer and spin it sideways when hauling to shows.
Edited by im4racin - 26 Sep 2020 at 1:26pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 8:15pm
Always unhook bottom pins first, lower head until there is one gap at bottom. Block header there. Unlock top pins and back out. Hook up top pins first then raise head and latch lower pins.             MACK
This page was generated in 0.176 seconds.
