snap coupler to pin hitch? |
Post Reply |
boggen
Bronze Level Joined: 12 Oct 2011 Location: centeral, IL Points: 15 |
Posted: 12 Oct 2011 at 9:51pm |
i have an allis chalmers CA (i want to say 1954 or 1953) model
it has a pin hitch. there is someone selling "snap coupler" post hole digger near me. i was wanting to know is there a conversion kit i can buy some place? to go from pin hitch to snap coupler on tractor? or... snap coupler to pin hitch on the post hole digger? i already have 2 bottom plow and disc for it, plus 60" belly mower. and draw bar. all work awesome. still need to buy a PTO shaft for a pull behind 5 foot bush hog that i have recently obtained. i can cut and drill holes, but i am no welder. i have searched the internet, but i have not seen any sort of images of the "bell" for snap coupler under a tractor, only the tongues on different implements. so even being able to DIY something up, is so far out of the question. |
MACK
Tractor salvage should have the bell. MACK
Pat the Plumber CIL
Orange Level Joined: 11 Sep 2009 Location: Springfield,Il Points: 4677 |
I do not believe the post hole digger attatches to SC bell,I could be wrong.Someone just restored a beautiful C or CA and posted pics of post hole digger attatched.
mnoonan NEWI posted some pics of his post hole digger and it does not connect to SC bell Search "post hole digger" and scroll down.Beautiful resto. May not be A/C model digger,do not know if there is a SC post hole digger out there. Edited by Pat the Plumber CIL - 12 Oct 2011 at 10:05pm |
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
sjerden
Bronze Level Joined: 05 Feb 2010 Location: Illinois Points: 159 |
I don't see a post auger with a snap coupler either. but If it does connect that way then why not just unbolt the coupler on the auger and put a pin hitch on it?
Edited by sjerden - 12 Oct 2011 at 10:45pm |
Orange Tractors
Silver Level Joined: 13 Sep 2009 Location: Butler, MO Points: 172 |
I don't know about a CA, but my grandpa had a homemade posthole digger for his WD. It utilized a rearend from a car, (Plymouth I think) and two pieces of andle iron the mounted on the lift arms with 5/8" bolts instead of using the lift latches.
The ugly old thing works well, untill you try to lift it out of a hole after it has screwed the auger under a substantial root, then you break the angle iron and have to weld new patches on.
Robert
1953CA
Orange Level Joined: 01 Jan 2011 Location: Burlington, WA Points: 505 |
I have a post hole digger that is snap coupler, and one that mounts on a D series.
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support" |
boggen
awesome!
thanks for the quick replies! i truely though i was in trouble and extra work ahead of me. i have not seen the post hold digger near me yet. mnoonan post http://www.allischalmers.com/new/forum/forum_posts.asp?TID=37694&KW=post+hole+digger&title=ca-post-hole-digger-pictures and link to mnoonan pictures https://picasaweb.google.com/mnoonan42/CAPostHoleDigger?authkey=Gv1sRgCNbcvbGCwIyNjAE |
1953CA
Even if it was snap coupler, all you would have to do is weld an appropiated sized pipe to the loop of the drawbar for the pin hitch...
Ray
Orange Level Joined: 21 Sep 2009 Points: 1979 |
I have a snap coupler bell for a CA for sale. 785-353-2392 |
boggen
just bought post hole digger and sickle mower
both from understanding hooked up to the guys Allis Chalmers WD tractor that had snap coupler setup. without any extra hardware. *rubbing head* i thought i had correct under belly connections for the sickle mower. but after dragging it home. and looking and measuring, I am not sure what i need. uploads/5982/S1220010.JPG uploads/5982/S1220009.JPG uploads/5982/S1220008.JPG uploads/5982/S1220006.JPG uploads/5982/S1220005.JPG uploads/5982/S1220004.JPG uploads/5982/S1220003.JPG uploads/5982/S1220001.JPG looking on google for "allis chalmers sickle" i came across this picture, but the picture does not show the actual connections underneath of tractor. (nor the large spring that looks like it connects to the under bellow of tractor.) reference link for below image http://www.chatstractors.com/061276_Allis_SC_sickle_mower.htm http://www.chatstractors.com/2006_implements/061276_allis_snap_coupler_sickle_mower_back.jpg when looking at.... http://www.agcopartsbooks.com (view guest) typed in "sickle" then selected "allis" the frame mounts / attachments look like.... 80R / 80R3 / 80S / 80T / 82R / 82S / 82T SICKLE BAR MOWER but unsure of model i have, to even get better reference numbers / parts. agco also had this list of pictures / parts numbers. 3 / 5 / 7 / B / C / B-IND / WC SICKLE BAR MOWER and 82SI SICKLE BAR MOWER Edited by boggen - 18 Oct 2011 at 12:56pm |
boggen
*rubs chin* next problem is "post hole digger" that was bought at same time.
it looks like it only connects to the lift arms directly. though my CA vs his WD has differently lift arms (shape). wondering if anyone has any better suggestions, than drilling a extra hole in each side of the PHD for the lift arms for C. and go at it? a slight tap, with hammer and the arms of the PHD just slide over the outside of the my CA lift arms. ((at moment belly mower is attached)) not the guys tractor, but showing rear end of a WD. and from way it looks end of frame just slips right over the arms on the WD. with no other attachments / connections. reference link for below picture http://www.chatstractors.com/1335_Allis_Chalmers_WD45_diesel_tractor.htm http://www.chatstractors.com/2007_Allis_Chalmers/1335_allis_chalmers_WD45_rear.jpg Edited by boggen - 18 Oct 2011 at 3:21pm |
AC WD45
Orange Level Joined: 28 Sep 2009 Location: Mid Michigan Points: 1993 |
One trick my old boss had for his WD was he "made" a snap coupler, he took a "pintle" hitch and welded it to a bracket he made up. Pin it in place, and drop the eye into the pintle.
German Shepherd dad
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
On the mowers an R is a rear mount, an S is a side mount and a T is a trailer type with wheels. Yours looks like the R. I don't know enough about mowers to help any more than that.
MACK
The mount bracket is on your mower. Remove drawbar assy, pull wedge pins out of mower(they have the chains on them) and remove from mower. Put the hitch from mower to tractor where you removed drawbar bail. It slides over thebolts in front and pins in rear holes. The spring hooks to a bracket in right finfer bolts.
The post digger slides over the two lift arms. MACK
boggen
thanks everyone!
looking at.... www.agcopartbooks.com clicked on guest typed in "CA" then selected "agco allis" selected CA tractor or typed in "sickle" then selected "agco allis" selected 80R sickle mower first picture is what i have on the CA second and third picture is what i am looking to buy other words, snap coupler brackets. i do not believe i need the actual bell or guide, ( i do not have anything that requires it ) if i had the left and right bracket. i do believe i will have what i need for the "allis chalmers 80R sickle mower" i assume i can find the pins and bolts / washers at run of mill store. but if someone already has them. might as well get them. 3rd picture, is from the agco 80R sickle mower manual i do not have the 2 brackets, i have everything else. for the sickle mower just not these 2 items specific for the CA. p.s. sorry for large pictures and multi edits of post. trying to narrow things down. and it kinda hard to in a small little edit window, till after i see things. Edited by boggen - 19 Oct 2011 at 12:09pm |
Post Reply | |
