Snap coupler field cultivator? |
Dan Hauter
Joined: 06 Feb 2011 Location: Carlinville, IL Points: 1254 |
Topic: Snap coupler field cultivator?Posted: 29 Apr 2020 at 8:49pm |
Did Allis-Chalmers ever make a snap coupler field cultivator? Not a row crop cultivator but a light tillage tool?
tomstractorsandtoys
Posted: 29 Apr 2020 at 10:03pm |
Yes. Dad bought one at a consignment sale about a 10-12 footer. I never saw it because the next day a collector called and wanted it real bad. He got over twice what he paid and did not have to haul it.
Tom |
wjohn
Posted: 29 Apr 2020 at 10:11pm |
This was one version. I picked this up last year from a forum member. It's currently set up for a pre-Snap Coupler WD but I also have the Snap Coupler drawbar. I believe there was a heavier version possibly made by the Oxnard Works as well.
Steve A
Posted: 30 Apr 2020 at 7:05am |
I have one that my neighbor gave me 20 years ago. Similar, but the brackets are made of 3/4" X 3" heavy flat stock and adjustable. Somebody torched off the snap set up and put on 3 point attachments long before I got it. I was going to take it to Dads, put it on the 170, and try using it along with a disk to work up a couple of sandy loam fields.
Roach
Joined: 30 Jan 2013 Location: Wheeler, IL Points: 280 |
Posted: 30 Apr 2020 at 8:54am |
I've got a 12 footer that I converted to 3 point back in the late 70's.
I will try and get some pics in the next couple days. Still use it once in a while for food plots and gardens. |
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2154 |
Posted: 30 Apr 2020 at 8:56am |
I have an 8' one. Like it a lot. Does a nice job. If this works right, following are some pictures.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Steve A
Posted: 30 Apr 2020 at 9:38am |
Just went out and looked at mine again, loosened the bolts with ATF and adjusted it. It's the same model as the others. What grade bolts did they use to hold the cultivator shanks?
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4063 |
Posted: 30 Apr 2020 at 2:52pm |
I'd like to have one some day. I have work for a small cultivator.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1488 |
Posted: 30 Apr 2020 at 3:59pm |
We had one of those on the farm. Worked well!
wjohn
Posted: 30 Apr 2020 at 8:22pm |
How robust are they? I have a couple of small fields that used to be old town lots and there are a few pieces of brick, chunks of rock, etc. but probably nothing that's like bedrock sticking out of the ground. I don't think the tines are available anywhere so I'm concerned about tearing it up.
Roach
Posted: 01 May 2020 at 1:08pm |
They are pretty tough and I would not worry about bricks and smaller rocks. The only problem I ever had is if I had too much ground cover that I had not disc up and then it would plug up. Other than that they do a good job. I need new spear points someday.
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3280 |
Posted: 02 May 2020 at 6:49am |
![]() ![]() Here's a couple pics of mine from when I first got it. It had a couple broken tines when I got it. And I broke another 1 or 2 trying to used it after plowing. Right now it is set up to cultivate potatoes with hiller discs. |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
