Sight glasses
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: Sight glasses
    Posted: 19 Jul 2018 at 9:45pm
Greetings all,
Was doing some work on the tractors today (8050), and had trouble seeing the oil level in the rear end.  The sight glasses were dirty, so it was hard to see the oil.  I found a plug of the same size as a spare sight glass I have, so I unscrewed the top one, and capped the hole.
I then cleaned the glass so it was clear.  Glass was dirty/hazy.  After it was cleaned, I placed it back in, and was back to business.
I assume the haze in the glass is just materials that are in the sump, and have not gone through the filter yet.  Also, do people clean those regularly, or does regular transmission filter changes keep your glasses clean/clear?  I replace my trans filters every year, so I am keeping up with that.  Perhaps just using lots of implements is bringing in contaminants?
Thank you,
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2018 at 10:03pm
I always clean mine when I replace the oil in the sump.  Sometimes I pull them when I fill up and use them as level plugs.
Hurst
1979 Allis Chalmers 7000
5800 Hours
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2018 at 10:04pm
I think the glass just gets dirty from years, don't think the filter change will help that at all.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 7:05am
I always have a heck of a time seeing oil in there or not.  I've given up trying, I take out the top glass, add oil until it just starts to show up in the hole.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 8:27am
In our radiators we sometimes use the round sight glasses with the plate behind the glass and the ball between the plate and the glass. The ball rolls around and keeps the glass and plate relatively clean. Might work for oil too.
cheers,
Creek
Have spacesuit, will travel
This page was generated in 0.945 seconds.
