Sickle mower question
mizzouplumber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mizzouplumber Quote  Post ReplyReply Direct Link To This Post Topic: Sickle mower question
    Posted: 05 Aug 2017 at 10:29am
I just got my dad's 82R mounted on the D17. But I can't figure out how the long spring that is under the right lift arm mounts to the tractor. If anyone has picture of this. I am thinking that part is missing.
I know the threaded end is broke, but I can fix.
Is there a source to find a replacement belt.
1957 Gas D17 Series I
Allis 80R bar mower
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2017 at 10:57am
There needs to be a "U" shaped bar that is under the RH axle housing.  It is called a "Spring Anchor Bar" according to the AGCO parts book.  Go to this link.
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79001529
On my CA, it mounts to the same bracket as my rear cultivator mounts to.
Dale
Edited by bauerd44 - 05 Aug 2017 at 10:58am
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2017 at 11:24am
If you have that spring, you have an 80R mower.  And the bracket you need on the axle to attach the spring to is probably on the tractor it came off of. I will post the section of the manual....Dale
Orangereborn
Dale Schafer
964 192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 9:26am
I think the piece you are looking for is listed in the classified ads section by Matt .Or you could make your own bracket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mizzouplumber Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 9:58am
I found that listing late last night. I have contacted him. If it's not available , I will probably just make one now since I know what I need. Thanks for everybody's help.
Allis 80R bar mower
This page was generated in 0.042 seconds.
