Sickle mower question |
mizzouplumber
Topic: Sickle mower questionPosted: 05 Aug 2017 at 10:29am |
I just got my dad's 82R mounted on the D17. But I can't figure out how the long spring that is under the right lift arm mounts to the tractor. If anyone has picture of this. I am thinking that part is missing.
I know the threaded end is broke, but I can fix. Is there a source to find a replacement belt.
1957 Gas D17 Series I
Allis 80R bar mower |
bauerd44
Silver Level Access
Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
Posted: 05 Aug 2017 at 10:57am |
There needs to be a "U" shaped bar that is under the RH axle housing. It is called a "Spring Anchor Bar" according to the AGCO parts book. Go to this link.
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79001529 On my CA, it mounts to the same bracket as my rear cultivator mounts to. Dale Edited by bauerd44 - 05 Aug 2017 at 10:58am |
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
orangereborn
Posted: 05 Aug 2017 at 11:24am |
If you have that spring, you have an 80R mower. And the bracket you need on the axle to attach the spring to is probably on the tractor it came off of. I will post the section of the manual....Dale
Orangereborn 964 192nd Ave New Richmond, WI 54017 715-247-3079 715-781-2055 ![]() |
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
Posted: 06 Aug 2017 at 9:26am |
I think the piece you are looking for is listed in the classified ads section by Matt .Or you could make your own bracket.
mizzouplumber
Posted: 06 Aug 2017 at 9:58am |
I found that listing late last night. I have contacted him. If it's not available , I will probably just make one now since I know what I need. Thanks for everybody's help.
