Sickle Mower on CA
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Sickle Mower on CA
    Posted: 23 Oct 2015 at 8:41am
What would have been the most likely side mount sickle mower to have been original on a '51 CA? Anyone have a picture of one on your tractor?
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2015 at 2:19pm
Jim,  That would be the Allis Chalmers #5 mower.  It was basically a B-C mower adapted to the longer frame of the CA.  You would buy the basic mower and cutter bar then add the mounting and lift kits for whatever tractor it was to be mounted on.
An interesting feature of the #5 mower was the two pulley drive.  They used smaller belts reinforced with steel cable to transfer the power from the PTO shaft to the mower.
If you can get a copy of MR. SWINFORD's "Allis Chalmers Farm Equipment" book on page 274 and 275 there is a picture of the #5 on a CA with a small article about it.
Hope that is some help.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2015 at 2:33pm
Thanks Bill.
Jim
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2015 at 5:48pm
Well I just happened to check that book out from the library last night!
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2015 at 7:38pm
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2015 at 10:19pm
The #5 mower is one that you only want to install once. It takes 2 me and a small boy to get it on. I think that once it's on you would want to leave it there. It looks very heavy. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
