Sheet metal work
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Sheet metal work
    Posted: 26 Sep 2016 at 3:39pm
Show some of your successful or maybe not so successful repairs.
I'm trying to patch some WD fenders...
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 5:12pm
Charlie,
You asked for it!:)
 Here are some pictures of WD fenders and the repairs, and finished product.
This set was purchased at a flea market. Don't let the shiny orange paint fool you, they were in rough shape. Dents all over and lots of rust.
Here is a set of WC fenders I converted to WD. They had rust in all the right places, and needed some attention too!
hot dog shape from original tractor donor fender
more holes
more patches
shapes welded in place
several torn areas welded.
into the e-tank
some filler, sanding, primer, and PO#1!
The other set on the narrow front WD.
By the way these are like sanding a jelly bean! Sand in all directions.
Edited by Sugarmaker - 26 Sep 2016 at 5:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 5:23am
Wow!
That was amazing!
Charlie
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 6:55am
AMAZING!  But I am curious as to how they hold up.  I was told that WD fenders vibrate enough to cause the cracking over time.  Wouldn't they start to crack again in new places eventually?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 7:34am
Folks,
 Thanks! Hope those pictures may help Charlie (sorry) and others with some AC body work. Time will tell how they hold up. I have one small crack so far that is in the filler material. Welding in new steel and using minimal fillers is probably the best approach. Would new repro fenders have been easier? Yes! But we learned a lot.
Edited by Sugarmaker - 28 Sep 2016 at 9:05pm
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 8:23am
I love what you did and I think repos are thinner than originals?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 8:34am
Once again, you do Great work Chris. That takes a lot of talent!
Then again, I think it takes a lot of talent AND also a lot of patience! I'm a little short on both.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 11:07am
Chris if you are not a body man you are now. Good job. You have the weld in patching down.
I still do a little. Last one was welding in a new horse trailer front skin.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 7:31pm
Chris anytime you have to use filler especially if it's going to be thick use some filler they call Alumalead ( not spelled right). It's holds up to stress and vibration a lot better than regular filler.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 7:39pm
Chris that is amazing work. I always learn something new when I read your posts. Thanks for all the photos. Do you use a mig welder for that? Seems like it would be easier then a stick on the thin stuff.
As to reproduction fenders be glad you could fix the old ones the new ones are thin and dented out of the box. I have a pair and would have to do a ton of work to get them to look half as good as those you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 9:11pm
Charile,
 We want to see some pictures of your WD fender project! Hope we can lear a thing or two from you!
I had never heard of that Alumlead filler?
I have a older Mig welder that is pretty good on thin materials. I just wish my eyes could see well enough to weld. Getting tougher all the time!
Thanks for the kind words, the fenders and tractors are 20-30 footers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 9:18pm
Chris sounds like you need to go visit the eye doctor....
When I read that all I could think was the day my mother finally admitted she was blind only to admit after I got her to the eye doctor and they removed her cataracts that she should have had it done years earlier.   I know they can't fix everything but if they can be fixed I say get it done your site is something you don't want to loose....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 9:22pm
Dan,
 its called getting older and tri focals and magnifier in the hood and still cant see the darn weld puddle as well as I would like. Just frustating some times. I stick welded a bunch as a kid on my first job and liked to lay down a nice 1/2 inch bead of weld.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 9:40pm
Yup Chris i do understand that. I need to get out my welder and get build up my skills there. Never could get good at starting a weld without sticking the rod. If I could just get the Ark started it I could run a descent weld.... that is a skill I have alot of respect for in others.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 5:08am
I was slacking and didn't take pictures.
The portion above the bolt mounts was bad so I cut that and put in a new patch. I was having burn through issues on my wire feed even on the lowest setting. Ended up putting a lot of wire on it and grinding it down but it did blend well.
I was going to leave the tack weld dips as is as they must have come from the factory that way but then I saw yours and decided to blend them in.
I tried to shape the fenders but I really need an English wheel, they will have to suffice as is.
Trying to patch two dents on the top of the nose piece. Contour blending is hard!
I think it looks good and then shoot it with primer only to discover flat spots or something else needing redone...
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 8:19pm
Charlie,
 Your fix sounds about right where they normally rust out. Sanding painting and doing it again sounds about right too!
Just get us some after pictures!
