Serious Hydraulic leak
MB 121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MB 121 Quote  Post ReplyReply Direct Link To This Post Topic: Serious Hydraulic leak
    Posted: 10 Jun 2020 at 4:48am
I have a serious hydraulic fluid leak all cylinders including loader were lathed re packed and don't leak a drop. Brand new lines. I have degreased the entire tractor it appears the leak is towards transmission selector also had hydraulic control hieght block rebuilt new o rings felt dust seals doesn't leak a drop from it either. It will leak while running or not.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 5:13am
A little more info would help us help you.
Would assume it is an Allis Tractor you are talking about.
Need to know the Model and year ( or Serial Number ) to begin with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MB 121 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 6:27pm
1953 WD45 don't have serial number on me I can look it up
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 1:30pm
Did you put the oring between pump and control valve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MB 121 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 4:53pm
Replaced it when I had control valve rebuilt. Not leaking there it's dry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 6:57pm
"It will leak running or not"...….Leaks what ????   Hydraulic oil??? or transmission/torque tube oil?? You mention transmission selector??   You know a good picture or two would certainly help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MB 121 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 7:20pm
Hydraulic fluid. The main place I see it dripping off is the PTO housing drain plug already replaced PTO gears housing seals and gaskets. PTO was 90 wieght by I&T shop manual this is hydraulic fluid. Tried uploading photo says to big not sure if I'm doing something wrong there or what.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 7:45pm
If you had the hydraulic pump off the tractor, I'll bet you've damaged the gasket reinstalling the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MB 121 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 4:42am
Pump hasn't been off it is strong and runs well mostly everything I've put on it it lifts only thing I found it won't pick up is a large round bale with a spear.
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 6:09am
See https://www.allischalmers.com/forum/pictures_topic168921.html for instructions on photo posting.
