serial #
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Topic: serial #
    Posted: 13 Feb 2020 at 2:24pm
I have a WD45 that does not have a serial number on the rear housing. Does that mean that maybe it was a replaced part from factory?
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 2:36pm
NO it is stamped into the housing, It is either covered with a lot of paint or someone has removed it, Usually scrape the paint with a pocket knife and it will appear.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 2:41pm
Take a close look. Sometimes they are covered by paint and hard to see. I know where mine is and could hardly find it a few minutes ago. Left side above the square set screw and below the hole for brake spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 2:46pm
BUT, if there is no serial number in the usual place just ahead of the lift shaft, next to the square head brake shoe adjustment screw on the left side, it is a new housing that was replaced at some time in its life. The reason?? Someone ran the rear end out of oil and the pinion shaft bearing locked up and cracked the housing bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 2:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 2:53pm
There you go. Left side in middle of pic. Can hardly see it. I really struggle getting these pics on here but this is good practice! 😀  Above the square set screw on the flat just below the line. Mine is 175421. I can see it all with a good light shining on an angle and maybe my close up glasses on. LOL.
Edited by Ed (Ont) - 13 Feb 2020 at 2:57pm
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 4:36pm
I recall discussion about this in the past.......sometimes the serial # is located on the edge of the LH brake housing opening next to or under the cover.
That may have been for early WDs only?
I saw a picture somewhere......now, if I could only remember where!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 4:56pm
Brian the pic is right above your message! 😀. Let me know if it is not showing. Was posted from iPad.
Edited by Ed (Ont) - 13 Feb 2020 at 5:29pm
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 5:33pm
Mine have wd before the number.---yes they are hard to read as some of them were barely hit and the weather/rust/sandblasting/etc. has about wiped them off.
Location in pic. above is the only place you will find the numbers. ---If it aint there---you aint got one!  ---- Tractor may have been stolen sometime in its life which would mean no number.
I have seen several on auctions that didn't have numbers. ---I assume they were stolen then put up for sale.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 7:54pm
Early WD had # just to right of left brake cover.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 7:18am
ac fleet......They all say WD xxxxxxx. They do not say WD45 xxxxxxx.  The WD45 began at a certain serial number, but the tractor is still a "WD" series.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 7:22am
If it has the original hydraulic pump yet, I believe the serial number on the pump should match the serial number of the tractor..... if it has the original pump.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 7:41am
I know were it should be, because I have two more 45's, and I have looked at a lot of tractors for other guys. It is not covered with paint!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 7:48am
Then I'd say you have what the doc says you have, a replaced housing. If the hydraulic pump is original you could stamp that same number into the housing. If I'm right about the pumps sharing the same serial number.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 7:49am
I don’t see a WD on mine. I will take another look but it was painted many years ago so maybe too much paint.
Just took a good look at the original pic on my iPad and yes the WD is there! Just to left of the first digit. Very faint and a bit smaller than the numbers. Maybe done in different way. Harder to see in post - pic was downsized.
Edited by Ed (Ont) - 14 Feb 2020 at 8:02am
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 8:10am
I see WD Big smile
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 8:17am
How do you do that? LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 10:25am
I know they don't say wd-45! --- I mearly said that the 45 has the letters wd before the numbers! the wd's only have the number---no pre letters. ---- it don't matter anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 10:58am
As I (and Mack) said, early WD #s were sometimes near or under the RH side of the LH brake cover on the top of the housing.
I know that sometime in the past someone posted a picture of a number there but I don't know where to find it.  I remember someone posting a picture of the number on the hydraulic pump also but  don't know where to find that either.
The only place I have seen the number myself is where Ed (Ont) shows it in his picture.
However, the "Operating Instructions and Parts Illustrations" for the "MODEL WD-45 TRACTOR" shows the location in two places. I'm assuming in one of either of the two
places.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 11:04am
No one on here is criticizing you! I for one did not know about the letters in front and am glad that I do know about it now. So I guess I'm the dummy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 11:33am
If it turns out that it really has NO number and is a replacement housing, it would be a perfect match for my WD-45 with no engine number.
Could make it anything you wanted it to be.....maybe even somebody's  grandpa's long lost WD-45?
