Seed plate info |
Shamrock Farms
Topic: Seed plate infoPosted: 08 May 2017 at 8:39pm |
Greetings all. I'm new to the forum and AC equipment. I recently acquired a model 74 planter and am looking for information on seed plates. It came with corn,bean and sorghum plates. I'm wanting to plant a sunflower patch to dove hunt over and am wondering if there is a sunflower plate and/or spacer required since the black oil sunflower seeds are so thin. Any info or help including advice,part numbers and contacts for purchasing these parts is much appreciated. THANKS!
shameless dude
Posted: 08 May 2017 at 9:40pm |
are those plates the big ones that mount vertical? I have some plates, but will hafta look at them to see what seed they may take.
Shamrock Farms
Posted: 08 May 2017 at 9:44pm |
No these mount horizontally and are about 7 inches in dia. The ones that came with it are aluminum but I am not opposed to using plastic ones.
shameless dude
Posted: 08 May 2017 at 10:12pm |
I gots skads of those, lemme check
Shamrock Farms
Posted: 08 May 2017 at 10:25pm |
Great! I only need 2 since this is a 2 row planter now.
shameless dude
Posted: 08 May 2017 at 10:26pm |
I looked on "Lincoln ag" web pages, and the sunflower plates are a lot like the corn plates for flat kernals. do you have the adapters to make the deere style plates work in allis planters?
Shamrock Farms
Posted: 08 May 2017 at 10:29pm |
No, sure don't. It only came with the cast aluminum AC plates.
shameless dude
Posted: 09 May 2017 at 3:29am |
if you use the deere plastic plates, you hafta have an adapter that goes in the middle. I think I also have some SS plates, and some cast iron ones, i'll look to see what they are for.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3194 |
Posted: 09 May 2017 at 6:20am |
Big difference in sunflower seeds.Grey stripped are very large the oil type are about
half that size.Also been my experience if there are many deer around they clip off the Sunflowers not long after they come up same with Blackeye peas.Broadcasting Buckwheat and Sunn Hemp as a Summer draw will work a lot better |
Shamrock Farms
Posted: 09 May 2017 at 7:07am |
I'm planning on planting the smaller black oil sunflowers for a dove plot. You are correct that the deer love those new sprouts and I plan on losing a few but hope they won't clean out a couple acres. In past years I've just broadcast the seeds but they were just too inconsistent and mostly overcrowded resulting in smaller heads. The ones that the deer hit still produced heads (actually multiple heads) but were noticeably smaller.
Gary Burnett
Posted: 09 May 2017 at 7:26am |
When I broadcast seed on seed plots I mix the seed in the fertilizer and can control the
amount and thickness of the seed better. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 09 May 2017 at 6:24pm |
You can take some bondo, fill the holes in a set of plates, then grind out the holes, to fit your seed. Just use a dremel tool, and grind till the hole fits your average SF seed...
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2337 |
Posted: 09 May 2017 at 8:39pm |
I think you can get new plastic ones pretty cheap, Might be the easiest answer.
Shamrock Farms
Posted: 10 May 2017 at 5:14pm |
Update: I found a dealer with an old set of plates and a set of spacers that will work. I think they may be the popcorn/sunflower plates that are listed on some charts but can't read the numbers.Also picked up a set of adapters to use the Deere style plates. Just took a few phone calls and a road trip to the dealer. Thanks everybody for the input.
shameless dude
Posted: 10 May 2017 at 8:54pm |
new plastic plates are $25. each now.
Shamrock Farms
Posted: 11 May 2017 at 6:36am |
I got a heck of a deal then...plates and adapters for $15 but had to drive 115 miles to pick em up.
