Seat for a B
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Topic: Seat for a B
    Posted: 09 Oct 2016 at 6:07pm
Are there plans available to building a seat for an 1938 Allis B.
Thanks, Nella
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 6:16pm
The cushion, or the frame?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 6:20pm
the cushion
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 6:26pm
I wonder what the original ones had inside. Just springs or some kind of filler?
Ken?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 7:12pm
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 9:44pm
The early seats had a zig-zag wire springs. The later one used coil springs. They both used a 3'4" plywood base about 14" X 28" with 2 3/4" hole drilled in it. To leave the air out as you put your butt on the seat. The filling was cotton and horse hair or fiber as stated in the other post. And was covered a green cotton waterproof duck material.
I wood not want to sit on a vinyl cover for long, it will make your butt sweat. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:03am
The seat would make you sweat,I put in a lot of hrs when I was young cultivating corn with
a B.We did have an umbrella rigged up on it to get a little shade.
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:59am
We made both the seats for our B's. Just cut a piece of plywood to the size of the seat box. Then we just got some high density foam (like is used in atv/motorcycle seats) and a vinyl material from a craft store. Wrap it around and staple to the wood with a staple gun. Mine is covered with vinyl I cut out of an old bus seat. I am fine with the vinyl but you can pick out any cover you want. Nice part about the vinyl is if they get wet you can just wipe it right off and not have water soak into the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 12:11pm
Nella, here is a place where you can get them:
http://www.allisbseat.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 1:00pm
So did they originally have the seat back cushion?
peterh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 1:56pm
no, the seat back cushions are not original, but they sure make it a lot more comfortable, especially if bouncing around a little. I bought both of my seats and backs from allisbseat.com, and im very happy with them. One set is black, the other is orange with black trim, which looks very sharp.
1947 C, 1949 B, 195? CA
60 series cultivator
fertilizer side dresser
2 bottom snap coupler plow
1 bottom plow, Cole planter
dudley wallace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dudley wallace Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 3:38pm
I went thru hy/capacity tractor parts and it was a nice seat with a padded back the back was on gleaner combines and had the sam bolt pattern
a member of hendricks county antique tractor and machinery association club.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 9:03pm
I believe some early B's had a padded seat back. I think I remember someone talking about real early ones had a wood back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 9:37pm
In the 1938 B operators manual it shows a back, item #8,  #207354, quantity 1, name, seat back.
This page was generated in 0.207 seconds.
