Sealing 8000 series cab
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Sealing 8000 series cab
    Posted: 10 May 2020 at 3:55pm
 Got a 8030 and 8050 I struggle to make the top of either 100% water tight.  How do other folks go about it.  I thought about using the caulk on a roll they use to seal seams on grain bins.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 4:01pm
Silicone the bolts. Thats stopped it on one of my 8000s. Haven't done the others. Plus a new seal that goes under the top helps too.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 10:32pm
AGCO has a gasket kit and rubber washers for the bolt.  Haven't had any problems with the one I put on my 6080.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 11:34pm
Buy rubber washers for the bolts or make your own with inner tube and a hole punch.
