Sealed beam headlight bulb part niumber
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Sealed beam headlight bulb part niumber
    Posted: 05 Dec 2017 at 5:47pm
Any one know the bulb number for a sealed beam headlight 12 volt for a D14?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 9:02pm
NAPA should be able to look it up for you.  Last ones I got came from AGCO though.
markat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markat Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 7:04pm
I was going to post the same question this morning. I checked Napa with no luck. Does anyone know what the part number for the 12 volt sealed beam ,4 and 3/4 bulb is? Napa or agco number, they can cross it to find it. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 10:30am
The part number I see in the book is 230232
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 10:39am
NAPA 4411
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 10:55am
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 3:52pm
Allis Chalmers D14 Light Bulb, Sealed Beam, 12 Volt - 373662R91
www.yesterdaystractors.com/Allis-Chalmers-D14_Light-Bulb-Sealed-Beam- 12-Volt_373662R91.html
Allis Chalmers D14 Light Bulb, Sealed Beam, 12 Volt for sale, 373662R91. This 12-VoltSealed Beam has Double Contact. It is 35 Watt. Has a 4.365 inch outside diameter. Replaces: L4411, 230232, 70232232, 70276858. for sale.
Steiner also lists them. According to them it fits everything from D14 to 175 and 190. Anyone tried them???
Would that be the same as the outer 2 bulbs in a 4 lamp automotive application in older cars? They are double contact. In other words 2 small round low beams.
Edited by Ed (Ont) - 07 Dec 2017 at 3:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 4:41pm
OK... according to some places it's a 4.5" bulb, commonly used in 'exit' emerg light units...some have them for $6 a bulb....LED ones are kinda pricey..
for some reason I had been looking for 4 3/4" units... 4.5 IS whats on one of my D-14s though who knows if it's correct.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 5:17pm
Newer D14s with 12 volt systems use 4.5" sealed beam headlights - these are still available.  Older 6 volt D14s use 4 3/4" lights that do not look like anything else - these are no longer available.
I did manage to get a smaller sealed beam to fit in the older 6 volt light housing.  I got creative with them and they fit nicely.  No one would know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 5:53pm
hmm that explains my fleet...3 were 6v,but modified for 12,so 'someone' replaced light housings with 4.5 ones (12V).
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 6:14pm
L4411's will work for the 4 3/4, but you will have to split some fuel line to make a rubber ring to take up the space to the clamp
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 6:35pm
Try some of these for filament lights...
 Wagner H7610  50 watt .
   There are HID's out there too as well as the LED lights which won't look origional unless you spend some big bucks...
 When converting the old WD45 to 12 volt, I put the Halogen in the old light fixtures with small daps of silicon sealer in four places to keep the glass from rubbing the origional glass lens and then made an assembly in the back side to put tension on the sealed beam... man did that give it light. Refigured the old push pull switch up so I could turn on the front and tailights on the first notch out, and second notch, (all the way out) was for the second set of firecrackers on the hood. Switch all the way in , everything was off. Sure was fun cultivating at night with it... see up close, see out far and see where you been. LOL
This page was generated in 0.093 seconds.
