Rust in gasoline tank
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: Rust in gasoline tank
    Posted: 19 Sep 2012 at 6:41pm
Have a "G" with a rusty tank, did the gravel thing and lasted about 1 year and now plugs the filter again perty quick. Any better ideas?
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 6:44pm
You may have done the gravel thing but you need to coat the inside, I use Red KoteTongue
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 7:49pm
I did the red kote thing . I cleaned out the inside of the tank first by putting nuts and bolts in it and rotating it . I did this over a year ago and it works great. You need to follow directions on the box and seal it .
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 8:34pm
Well, there are a few ways. The best thing is to always leave the tank full of fuel as this will help prevent the tank from rusting.
The best way is to use electrolysis as it will remove the rust and help prevent it from forming again.  There is a thread on here with details, search for the word 'electrolysis' here and on Youtube.
One of the easiest, but dangerous, is to remove the petcock, screw in a section of pipe with a runner hose attached, or connect a rubber hose to the outlet.  Add several bottles of The Works toilet bowl cleaner (Hydrochloric acid), fill to the top with water.  Let it sit for several hours .  Drain fuel tank into a bucket.  Now plug the hose, and fill tank with a mixture of baking soda and water.  The baking soda will neutralize the acid, let it sit for 20 minutes.  Now dump in some isopropyl alcohol, drain put some gas in, drain and then fill to the top with gas.
The good, your tank will look like new inside.
The bad.  You must wear safety gear; gloves, goggles, and a mask rated for harmful vapors. Hydrochloric acid is very harmful and should also be disposed of properly.  IF you don't neutralize the acid, it will continue to eat at your tank.  Here is a a link.
http://www.mopedarmy.com/wiki/Removing_rust_from_a_gas_tank#The_Works_.28toilet_bowl_cleaner.29
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 9:41pm
POR-15.  They have a kit with everything you need.  Did my one-seventy about 8 years ago.  Problem solved.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
carol View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carol Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2012 at 9:02pm
use a small extention pipe attached to the sediment bowl to go inside the tank about an inch, will help to keep from sucking rust off the bottom of the tank.
1976 185
1964 D17 III
1960 D12
1953 CA
1938 WF
1938 UC
1956 WD45 D
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2012 at 9:13pm
used the por 15 kit on a few bikes works great
This page was generated in 0.093 seconds.
