Roto baler table conveyor problem |
TB63
Joined: 01 Oct 2023 Location: Lawson Missouri Points: 8 |
Topic: Roto baler table conveyor problemPosted: 01 Oct 2023 at 7:58pm |
I tried to get my roto baler working today after sitting for 4 years. The conveyor on the table will not engage.
Mikez
Posted: 01 Oct 2023 at 8:01pm |
Welcome to forum
TB63
Posted: 01 Oct 2023 at 8:38pm |
Thanks. I should have included more info. The last time I used it it became clogged up and I couldn't get it free.
Today I finally unclogged it and got the belts spinning but conveyor isn't working. I've tried pulling the rope to get it going. I'm not sure if the twine mechanism needs to be reset or if it is the clutch. Any help would be appreciated. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5270 |
Posted: 02 Oct 2023 at 12:34pm |
There is a replaceable wear piece on the dog lever that engages and disengages the pickup conveyor. When it gets rounded it causes problems.
TB63
Posted: 02 Oct 2023 at 5:00pm |
Thanks Paul. I took a picture of the part I think you are talking about but couldn't load it on this page. It has a threaded hole in it like something should go on it.
PaulB
Posted: 02 Oct 2023 at 6:34pm |
Yes: That sounds right. It has a wear pad that bolts on there.
dr p
Joined: 24 Feb 2019 Location: new york Points: 1525 |
Posted: 02 Oct 2023 at 7:16pm |
Before mike finds the part for you, make sure the linksge is free. Stuff loves to set up after 4 years the latch plare could be frozen
TB63
Posted: 06 Oct 2023 at 5:08pm |
Well the conveyor started working so I decided to try a few bales. After going about 100 feet the baler PTO stopped and the tractor died. Basically the same thing that happened 4 years ago. Then I thought the hay clogged it up but now think something else is getting it into bind. Any ideas?
dr p
Posted: 06 Oct 2023 at 6:40pm |
Are the bale forming belts workly correctly? Sometimes the lower belt get caught by the upper belts . That can stall the tractor
TB63
Posted: 06 Oct 2023 at 6:52pm |
I will check that tomorrow. Thanks
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8775 |
Posted: 06 Oct 2023 at 8:07pm |
There's a brake drum on lower right side. Make sure that the brake shoes aren't rusted to the drum
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8390 |
Posted: 06 Oct 2023 at 8:53pm |
Use a bigger tractor!!
No, wait don’t do that! |
TB63
Posted: 06 Oct 2023 at 9:20pm |
I did loosen the bolt on the brake before I started but I didn't check to see if the pad was rusted. It ran fine and rolled a partial bale before it locked up.
TB63
Posted: 07 Oct 2023 at 7:22pm |
Hey guys. Thanks for the all the helpful advice. I was able to bale a few today. I took a brass hammer and tapped on the brakes and they popped free.
