Rotary Mower on a B
rrambo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrambo Quote  Post ReplyReply Direct Link To This Post Topic: Rotary Mower on a B
    Posted: 30 May 2012 at 1:43pm
How big of a rotary mower can a B comfortably handle?  I'm thinking 48" but was wondering if a 60" is too much?
I've seen my dad do some crazy things with his old 8n over the years so I know that these old tractors can/might handle more than they are rated for.
I'm hopefully about to buy some land (crossing fingers) and it will need a lot of cleanup work..  mostly tall weeds, bushes, etc., and I'm looking for a used rotary mower to use behind my B once I get it running.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 3:40pm
It will handle a woods L59  or L306 without any problems. an L59 is 60 inches and a L306 is 72". I have a L306 on a C. has the same engine as a B and never have a problem. if your wanting a Brush cutter than down size. I'd still go with a 60"
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrambo Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 3:48pm
Thanks.. I need to do some heavy brush cutting..  that is if I even get this property I'm trying to buy..  about 10 acres of heavy weeds, small brush.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 4:35pm
I would consider a 48" blade.  Why, in not heavy work the B can handle 60" but in what you suggest you are doing I would stay with 48".  Don't forget an overrunning clutch.  With a mower with that big of a blade they can "push" the B.
Take good care of my favorite.
Good Luck!
Bill Long
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 5:04pm
My B runs a 3-point, 60" rotary mower, works great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 6:12pm
For heavy cutting a 48" with an over run clutch would be right for a B. Light cutting it will handle a 60" just fine.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 6:55pm
  we have sold more L306,S THAN L59,S   if set up correct it will slip belt before pulling the engine  my 2 cents since 1990
