Rod bolt nuts
Railroader Tom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Railroader Tom Quote  Post ReplyReply Direct Link To This Post Topic: Rod bolt nuts
    Posted: 26 Nov 2015 at 6:46pm
How many out there replace self locking rod bolt nuts every time you rebuild a engine? And how about the wear on them every time you tighten them to check clearance. Just wondering how other people handle it, thanks.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2015 at 8:10pm
If a nut is torqued it should never come loose. That said,if a bolt stretches then the nut can loosen. Would rather replace bolt over nut.  MACK
