Restoring a tractor!! |
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2348 |
Topic: Restoring a tractor!!Posted: 21 Jan 2010 at 9:14pm |
When restoring a tractor, and wanting to really do it right, how do you guys clean a rear end housing that has 50 years of gunk all inside??? I would like to clean it really good, no one else will know, but I will!! Thanks, Ryan
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Posted: 21 Jan 2010 at 9:16pm |
Parts solvent, a solvent brush, rags, air wand and time.
CTuckerNWIL
Posted: 21 Jan 2010 at 9:23pm |
I let the 35 WC drain for a couple weeks(thick black nasty lookin stuff). Then I pulled everything out of the housing and started scrubbing and mopping with diesel fuel and rags.
DREAM
Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Posted: 21 Jan 2010 at 9:24pm |
Best way would be with a parts washer. If you are doing a full resto including paint, taking it to an automotive machine shop and getting it "hot-tanked" would clean everything inside and out pretty well, and remove most of the paint too. Not sure how much they would charge, but don't think it would be much. Another idea would be electrolisys, which involves water, some iron rods, a suitable plastic container, a battery charger, and a few other common items. This will take all paint and grease off of anything. I'm not an authoruty on it, have never tried it, but there are some experts on here that should chime in and give you the details. All of the other techniques I have used in the past(like an old wash pot, gas burner, and some Red devil lye) work well, but i'm not sure the EPA would like it. Hope this helps. |
Ryan Renko
Posted: 21 Jan 2010 at 9:41pm |
Its kinda like opening a time capsule!! You remove a cover that hasnt been off in fifty++ years, you don't know what you will find! Everything looks good, but covered with "Gunk"!!! Would like to clean the guts up alittle!! Ryan
Matt (Jordan,MN)
Joined: 12 Sep 2009 Location: Jordan, MN Points: 3814 |
Posted: 22 Jan 2010 at 12:35am |
I use variety of things. a parts washer or brake clean do work very good. I recently bought a hot pressure washer and this works good. If the gunk is really thick wipe it out witha rag first then wash it. If it is still greasey use some soap and scrub it with a brush and wash again. About the best soap to use is Simple Green. If you use it straight it will cut grease and Diesel soot. Matt
Brian Jasper co. Ia
Posted: 22 Jan 2010 at 6:56am |
I had the same issue on my Oliver 60. I have a 3 gallon bench top parts washer that i sat on the floor under the drain plug. An extension hose with a brush and mineral spirits is all it took to wash all of the old stuff out.
gary ny
Joined: 11 Sep 2009 Location: verona ny Points: 361 |
Posted: 22 Jan 2010 at 7:04am |
I like to use laquire thinner .The price is not bad you put it in a paint gun a narrow down the pattern and you can reall y clean things up and it will evaporate fast .
Don Buck
Joined: 14 Dec 2009 Location: Southwest Virgi Points: 51 |
Posted: 22 Jan 2010 at 7:17am |
I am working on my 7th restore and I like to power wash then use a wire brush
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 22 Jan 2010 at 9:27am |
I've had good luck cleaning up the inside of engines using turpentine. (the real stuff, not the fake stuff)
Todd MN
Joined: 13 Sep 2009 Location: Belle Plaine MN Points: 22 |
Posted: 22 Jan 2010 at 7:40pm |
I take every apart then scrape as much out as possible, then solvent and presser washer.
Rick of HopeIN
Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329 |
Posted: 22 Jan 2010 at 8:21pm |
My B had a big side cover on transaxle so I was able to pull that and clean well enough with kerosene. I had filled a drained it a few times then just mopped up the palces that do not drain as well as I could. Also pulled the PTO shaft out to clean back there as I recall.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 23 Jan 2010 at 5:18am |
