Restored d17 project |
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 937 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Aug 2025 at 7:45am |
Blessed Sunday morning
Just got this d17 in that does not turn over at all and I’m guessing that it’s the crank seals are the culprit due to that being the last thing that was done to it. It has been fully redone inside out supposedly. I thought that I’d post on here from the start to finish so that it’s on the record. Btw the rear crank seal is still leaking….. ![]() Edited by 55allis - 17 hours 59 minutes ago at 5:55pm |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21818 |
That's a bad deal. I figured he'd have someone else (competent) fix it right and keep it after all the $$$$$ spent on it.
Update: found that all 8 push rods are bent and I call shot…
The rear crank seal leak ended up being the gasket had fell into the oil pan. ![]() ![]() ![]() Anything else I should check? I’m going to re-torque everything just to be safe. What are the common problems that cause pushrod bending? Don’t want it to do it again… |
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3901 |
In my case, the valves hung up in the head. Bent pushrods, bent valves, and left a mark in the piston where they made contact. Might even consider having the rods inspected as well.
Here is the original thread about it. https://www.allischalmers.com/forum/topic207217_post1773954.html#1773954
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87563 |
hard to believe that EVERY VALVE was stuck.. but possible... I would check the CAM TIMING... that would effect ALL valves hitting the pistons.... checking the rods for any BEND would be a good idea.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1246 |
X2 The previous thread linked above gave no indication as to whether or not this engine ever ran at all and no clues as to what type of 'overhaul' was done. Wrong pistons? Increased stroke? Shaved head? High-lift cam? Timing gears thrown in there haphazardly? ![]() I dunno, I wonder who does?
Funny thing is I don’t see any damage to the pistons or valves…
Bingo8 ![]() Bronze Level ![]() Joined: 04 May 2017 Location: Iowa Points: 18 |
Oh, I am keeping it. 55Allis is helping me out. It was an unfortunate situation. Unfortunately, I am not sure what I could have done differently when choosing him to restore it. He came highly recommended, has his work in magazines, and put clinics on for tractor restoration. Seemed like the right guy at the time. Hindsight is 20/20 but I am moving on with someone who hopefully can get it fixed up.
Found these numbers on on piston; AE 233
![]() Maybe a brand and part number? |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8610 |
Bout have to be cam out of time unless they're all stuck
I’ll remove the timing gears cover and check it out.
Think I’m still going to have to split the tractor due to a hydraulic leak in the clutch housing. Thanks!! |
There's something going on with that engine. It was a running engine !! That's why the rear seal was leaking...it RAN !! All 8 push rods bent on a running engine?? Makes you think the camshaft quit turning.
Could the governor fail and send debris into the timing gears and cause the cam to lock up?
Worn governor weights and timing gear damage are two things that go together. Maybe, just maybe, the governor weights blew apart while the engine was running AND no one was sitting on the seat to shut off the key ?? That might xplain the carnage. And as far as the man who restored this tractor goes, he might very well be the great restorer of SOME BRANDS of tractors, but certainly not a D-17 Allis-Chalmers. I can't imagine tackling multiple brands for restore projects and ever hope to be very successful at it. The nuances and quirks of each particular brand and model keeps most of us busy when repairing/rebuilding things.
...AND maybe the guy WAS sitting in the seat and reached around with a broomstick and shoved the throttle wide open on the carburetor... ![]() ![]() I spent 30 years in sawmill maintenance, and the single most difficult part about troubleshooting equipment problems was getting accurate, and COMPLETE information about what actually happened. What did you see? What did you hear? What was the machine doing immediately prior to the wreck? What was changed/adjusted? Etc.
