Replacing detent balls and springs in D17 trans |
Farrell(Utah)
Joined: 11 Sep 2009 Location: Springville, Ut Points: 558 |
Topic: Replacing detent balls and springs in D17 transPosted: 02 Mar 2019 at 1:50pm |
Just wondering about what is the best way to replace these"little buggars"?
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24782 |
Posted: 02 Mar 2019 at 2:15pm |
I have no D17 knowledge but.... buy 5 as 4 will drop into the bottomless pit of oil... when you're at the store the 2nd time, buy a magnet on stick to get the 'missing' balls not that that has ever happened to me...be SURE to account for ALL the balls or one WLL go crrrrrunch... Jay
Farrell(Utah)
Posted: 02 Mar 2019 at 2:21pm |
Yes, and wear safety glasses so one does not lodge in an eye
MACK
Posted: 02 Mar 2019 at 7:55pm |
Use a old rail or shaft same size as rail. Grind a U grove in one end. Push tool under ball and spring, rotate tool 1/2 turn. Push tool out with rail. MACK
Farrell(Utah)
Posted: 03 Mar 2019 at 2:18pm |
I got it done. Thanks for your comments.
