Replace seal on AC 185 RAM cylinder
briarpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote briarpatch Quote  Post ReplyReply Direct Link To This Post Topic: Replace seal on AC 185 RAM cylinder
    Posted: 22 Jul 2012 at 12:08pm
Does anyone know how to replace the large (3") seal on the RAM hydraulic cylinder that raises the left link?  This cylinder has only a single fluid input hose and uses the weight of the tool to lower the 3-point hitch.  Any special tools or tactics needed?
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 12:25pm
  No special tools needed, remove from tractor, remove hose fitting, slide snapring to groved space on the end of ram through fitting hole, pull out ram...
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 12:34pm
That snap ring can cause some frustration but you can do it. Patience is a virtue.
