Repairing Allis Chalmers Power Feed Box (wagon) |
Page 12> |
solidground
Joined: 12 Dec 2016 Location: Kingston, NY Points: 21 |
Topic: Repairing Allis Chalmers Power Feed Box (wagon)Posted: 16 Mar 2021 at 1:55pm |
Hi all, I just got an AC self-unloading wagon (power feed box) with a non-working front apron. The main apron that draws silage forward works fine, but the smaller one that pushes stuff out the side outlet needs to be fixed. For sure I need to replace the chain that brings power over to the gears that run it (not the apron, but just the chain), and the bevel gears that send power to that chain also are mashed up. I'm looking around for even a parts catalogue, but I can't find anything. Does anyone have any recommendation for how to find replacement parts? I know these wagons aren't common anymore. Thanks so much!
Mikez
Posted: 16 Mar 2021 at 2:25pm |
hi.
We’re not to far from you. Just up near Albany. We might have nos parts you need. Hopefully someone will have a parts book to get us numbers. I’ll also look for parts book.
Edited by Mikez - 16 Mar 2021 at 2:58pm |
Doug5545
Bronze Level Access
Joined: 22 Dec 2016 Location: Olathe Colorado Points: 16 |
Posted: 16 Mar 2021 at 2:26pm |
I have one for parts here in Colorado come over You can have them. Doug
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Posted: 16 Mar 2021 at 6:06pm |
I have a hard copy parts book for the self-unloading forage wagons and power feed boxes, so if you can post a pic of the parts you need, I can hopefully find the part # and Mike, myself and others might be able to come up with the parts for you.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
solidground
Posted: 17 Mar 2021 at 11:23pm |
OK thank you all so much- I really appreciate your help. I'm attaching a few pictures to show what I'm describing - there are the bevel gears that are gnashed up, and the chain (which is powered by the bevel gear and transfers power to the unloading apron) has broken. Do these look replaceable? |
HD6GTOM
Posted: 18 Mar 2021 at 12:39am |
I wonder who built them for AC. Were they a Badger built unit or something else?
dr p
Joined: 24 Feb 2019 Location: new york Points: 1539 |
Posted: 18 Mar 2021 at 4:55am |
I think Calhoun made them
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 18 Mar 2021 at 5:47am |
Soildground, Nice older AC power feed box.
The first AC power feed silage box (supplied by Calhoun Co., Cedar Falls, Iowa) production was marketed from about 1959-1962. It was usually monted on a 7 ton gear. 1964& later Power feed boxes were built by AC at Laporte - courteous Norm Swinford's 1914-1985 AC Equipment book. If your wagon sits on an AC running gear, it should have an ID tag located on its rear frame. If you tell me the numbers from that ID tag, I can tell you which gear it is. IMO, your wagon’s bevel gears don’t look that bad. That looks like typical wear on bevels. If you haven’t tried running them, attach some 2040/2050?? drive chains to it’s unloader & given it a turn by pto. Buy “A”(USA made)not “I” (Import made)replacement chain. US last longer, Import stretches quicker & wears out sprockets. Web links below. It’s unloader chain & slats looks like it uses a common “steel detachable chain”? Maybe 55 size - 1.281” outside width.? Here’s a web link to a supplier; https://www.shoupparts.com/A2040-2040-Roller-Chain https://www.shoupparts.com/A2050-2050-Roller-Chainhttps://www.shoupparts.com/SDC55-55-Steel-Detachable-Chain Edited by AC7060IL - 18 Mar 2021 at 6:36am |
AC7060IL
Posted: 18 Mar 2021 at 6:23am |
If it’s bevel gears are worn out. Their original AC part number is 515366. They are 18T & held onto their round drive shafts with a woodruff key part # 905845.
It’s unloader conveyor uses a 55H detachable chain, part# 921052. The conveyor drive chain part# 918563(108 links). It doesn’t mention its size. If its sprockets measure 1” between teeth(centers) then it probably uses 2040 chain. If it’s sprockets measure 1.25” between teeth, then 2050 chain. If teeth are 1.5”, then 2060 chain. |
solidground
Posted: 18 Mar 2021 at 7:05am |
Wow, thank you all so much for this information - I'll measure the chain to best match it. And yes, it does have an ID plate on the back. It says: Cat. No. 2013847 Serial 7 5999 Allis-Chalmers Mfg Co
AC7060IL
Posted: 18 Mar 2021 at 8:19am |
Your AC running gear is a model 700.
Mikez
Posted: 18 Mar 2021 at 8:43am |
ac7060 do you have a picture of the page from parts book with gears.
AC7060IL
Posted: 18 Mar 2021 at 10:33am |
This photo shows a picture of the apron's conveyor drive chain configuration near the bevel gears. Thought that might help Solidground know how to route it?
AC7060IL
Posted: 18 Mar 2021 at 10:35am |
Parts (2) of number 5 are the bevel gears located on the backside of it's pto input shaft.
AC7060IL
Posted: 18 Mar 2021 at 10:44am |
This is the continuation of the bevel gear parts (page 39)
Mikez
Posted: 18 Mar 2021 at 12:30pm |
have card on 515366 and have a box’s different of chain
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 18 Mar 2021 at 1:02pm |
Nice looking floor yet on that discarge, I take it that rope is for opening and closing the box into the discharge chute? Must have been parked clean or had no silage in it to not be rusted through.
Edited by Kansas99 - 18 Mar 2021 at 1:06pm |
JimWenigOH
Posted: 18 Mar 2021 at 3:15pm |
eBay item # 313076291944, A-C Parts List Self Unloading Forage Wagon, $20
AC7060IL
Posted: 19 Mar 2021 at 1:38pm |
Soildground, I curious - what did your wagon’s conveyor drive sprockets measure between their teeth?
Mikez, that’s amazing that you might have those bevel gears in your old new stock. you said, "have card on 515366 and have a box’s different of chain ." So I'm thinking that your part numbers are listed Numerically by card catalog? If that's correct, here are ALL the part numbers for the AC Power Feed Box. How many of these might you have in stock? Edited by AC7060IL - 19 Mar 2021 at 1:51pm |
Mikez
Posted: 19 Mar 2021 at 7:09pm |
well ac7060 the bevel gears I was thinking of fit an all crop harvester but yes the cards are the index filling cards. And have one one the number you posted. And one on the chain 921052 and it’s a-2050 and on box written a farmers name and “forage box” .
I’ll check out what else from your parts book. Are you looking for something also.
solidground
Posted: 19 Mar 2021 at 10:25pm |
Amazing, thank you all so much, for the info and the leads! I really appreciate the help-
solidground
Posted: 19 Mar 2021 at 10:29pm |
Oh and the old roller chain measures a pitch of 1 1/4 inch, with a inner width of around 3/8 inch. So that's the standard 2050, I think?
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 20 Mar 2021 at 6:06am |
I have a neighbor that has an old AC forage box sitting in his pasture that I bet could be had for almost nothing. I am about 4 hours north of you.
They were a very good box. If I remember right the bed apron (lags) ratcheted like many old manure spreaders, rather than a worm gear drive.
AC7060IL
Posted: 22 Mar 2021 at 6:19pm |
Mikez, So these index filling cards that you have, were they used in conjunction with a microfiche machine(scanner) like the dealership had back in the 1970-80s? No I'm not looking for any power feed box items. I just thought if it would help anyone, I'd share it's whole listing of the parts numbers.
Mikez
Posted: 23 Mar 2021 at 9:33pm |
no these were before that. I think iv see 1956 on some of them. You had the counter top parts book set up and of course the stacks of books under the counter lol. Then you look up what the customer is looking for and get the part number then go to the index cards, ours are in a wooden box also on counter and find part number which tells the bin location, simple description and how many on hand. Then your supposed to mark what you take out or add into stock.
WD45Diesel57
Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
Posted: 24 Mar 2021 at 3:20pm |
wish the floor on the front looked that good on my two wagons i need to do some fabricating on the both
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
feuchter
Joined: 02 Jul 2014 Location: portville ny Points: 15 |
Posted: 14 Sep 2021 at 3:54pm |
Is there any information on the input shaft in the main gearbox the pto Hooks to mine snapped off when the pto fell to the road and encountered a pothole
Mikez
Posted: 14 Sep 2021 at 8:10pm |
what’s the part number
AC7060IL
Posted: 15 Sep 2021 at 12:30pm |
![]() Edited by AC7060IL - 15 Sep 2021 at 12:31pm |
AC7060IL
Posted: 15 Sep 2021 at 12:35pm |
Page 12> |
